Shaking???
Old Jul 27, 2008 | 03:08 AM
HyphyDrivah's Avatar
Shaking???
I saw several threads with this same problem. Steering wheel shakes (very hard) while moving. I can feel it in the pedals too. However, unlike all the other posts, I feel it at all speed (gets worse the fast I go) and even when Im coasting. My first thought was wheel alignment, since I removed the front passenger tire to do the airbox mod. I removed and replaced this tire twice today, it seems fine for awhile, then starts up again. I think I did a good job on it, but this makes me wonder if Cobalts require special tools, expert knowledge, etc to replace a tire...
Can anyone help?
Last edited by HyphyDrivah; Jul 27, 2008 at 03:08 AM. Reason: Automerged Doublepost
Old Jul 28, 2008 | 04:57 PM
jdurlewanger's Avatar
Do you hear any noise coming from the engine? If one of the pistons isnt fire correctly it will cause the engine to shake which will then cause the steering wheel and pedals to shake. Have you changed your oil recently?
Old Jul 28, 2008 | 11:40 PM
It wasnt the engine. Sound was the same at any engine speed, idle or rev. It did speed up and worsen the faster I rolled, so I was sure it the wheels. Turns out my front driver tire separated. On my way to the tire shop, the tread ripped off...on the freeway. Ive had this car just over a month now, full warranty, and the dealer refuses to do anything. Oh well, time for new rims...
Old Aug 25, 2008 | 10:20 AM
I'm starting to notice this on my cobalt but it only shakes when I brake. I'm assuming this is a allignment issue and I was told to get a 'high speed allignment'. any suggestions?
Old Aug 25, 2008 | 04:23 PM
Turbo06Sedan's Avatar
jdurl.
Check your rotors / brakes.
Cobalts are notorious for warped rotors.
Which is the same for the OP.
My rotors were warped...therefor made my brakes prematurely fade due to the uneven surface.
GM will NOT warranty this, as they consider it from 'wear and tear'. AKA getting the brakes/rotors hot...then hitting water....would cause it.
My car had 13k miles when mine failed. I replaced them with some Powerslot Rotors & EBC Break pads....that was 25k miles ago and no more vibrating.
Old Aug 25, 2008 | 08:02 PM
sparhawk's Avatar
if you are with in 20,000 km GM will warranty brakes
Old Aug 25, 2008 | 09:09 PM
Same happened here after I got my new rims cuz the monkeys at the wheel shop used an airgun to install. Went with EBC drilled and slotted rotors and duralast pads. No more shaking and much better braking. Also, wasnt covered under warranty..."wear and tear"...Bullshit if you ask me
Murdered SS
Mar 8, 2016 09:33 AM
chefhhr
Oct 26, 2015 10:36 PM
Stealth06LT
Oct 16, 2006 07:38 AM
GTP
Jul 25, 2006 07:02 PM
Zoomyjs
Mar 20, 2006 12:35 PM
