shaking/vibrating problem with new wheels
Old Jul 22, 2008 | 05:18 PM
BigTizzle903's Avatar
On sunday i was down at Waterfest (huge vw/audi show for those that dont know) and i found a set of flik wasps with brand new nitto tires on them and the guy said 450. well they were dirty as hell but i didnt care i'd just clean them up so i got em for 400. put em on last night and i noticed at slower speeds (30mph) you can notice a shaking sensation (what you feel when the rotors are warped) but with no braking. then when you hit highway speeds it gets worse. when it comes time to brake it gets terrible even the steering wheel goes nuts. so i talked to a couple people and they said the wheels were out of balance so today i get em balanced and it didnt fix the problem.
now before i put on the new wheels i noticed the rotors were slightly warped but it wasnt bad and i didnt feel like dropping my car off for a day to get a tiny shaking sensation when braking out. but now with this problem not being unbalanced tires im thinking its either the rotors are so warped theyre hitting the pads even when the brakes arent applied. either that or one or more of the wheels are bent. im bringing it back to the dealer tomorrow and dropping it off for the day so hopefully that will fix the problem but do you guys have any ideas? i was just talking to a friend of mine and she said that if a rim was bent they would notice when it was balanced and tell me, which they didnt so that leads me to believe warped rotors or something worse. any ideas?
Old Jul 22, 2008 | 05:24 PM
elecblue06's Avatar
hey you'll need hub centric rings and to take off the brake clips i had the same issue when i got my rims on
you also should double check the balancing of it lemme see dem bishes lol
Old Jul 22, 2008 | 05:31 PM
brake clips? hubcentric rings? lol sorry man ive heard of the rings but dont know what your talking about. does that mean more money? lol
Old Jul 22, 2008 | 05:36 PM
elecblue06's Avatar
hub centric rings are really cheap and the brake clips are free to take off and a good place to start.. what are you doing at like 630? i'll be getting outta work and we can take one off for me to look at if you want
Old Jul 23, 2008 | 03:14 PM
ummmm i might be at the dr. ill pm you my number and gimme a call. im at fulton now. they had to replace the front rotors and resurface the drums. so ill see if that makes any type of difference.
and i got a friend that works there and hes gonna flash out SAI and see what he can do about the governor
Old Jul 23, 2008 | 03:34 PM
elecblue06's Avatar
did you pour water in your engine again i hear that ***** with your wheels
Old Jul 23, 2008 | 03:46 PM
OrngBalt's Avatar
Go get them balanced again... but at someone with road force balancing. I had my current wheels balanced and it didnt cure the vibration. I brought them to someone who could road force balance them and they did their best but my wheels were so warped it was too much to be cured.
He may have been selling them cheap cuz he knew they were garbage
Old Jul 23, 2008 | 06:07 PM
theneelster's Avatar
This is easy...was there a problem before you mounted the wheels? There's a problem after... Is there a problem when you re-mount your old wheels? If so then it's your brakes, if not then it's the wheels.
But I'm guessing the rims are probably f-ed and not the wheel balance. People should know better than to buy rims from some guy on the street or at a flea market.
Did you see when the designer of the aem bypass valve was so sure of his design he put his nsx on the line by literally plunging the filter in an aquarium? Hehehe awesome and stupid at the same time.
Last edited by theneelster; Jul 23, 2008 at 06:07 PM. Reason: Automerged Doublepost
Old Jul 23, 2008 | 06:22 PM
SthailifeS's Avatar
yea i have the same prob but mine got worse it pulls to the right and it feels like its running sumthin over wen i acelerate took to dealer twice second time they said its b/c im lowered and it throws my driveline angle off the tech said to either raise it back up or get this loosen all my mounts start the car and let the engine set in?? or shim the engine!! im now lost and need to do sumthin cus eventually sumthins gonna break.
Old Jul 23, 2008 | 11:11 PM
idk if the hubcentric rings arent too expensive ill try them out. and there was no problem with my old wheels. but when they balanced the tires they would have seen if the wheel was egged and told me. and i really dont want to drop another $40 to MAYBE fix the problem
Old Jul 24, 2008 | 01:54 AM
elecblue06's Avatar
hey man sorry i didn't get in contact with you today it started pouring when i left work check about the brake clips.. the hub centric rings shouldn't be too much.. if you have sometime tomorrow i can meet you someplace and take a look at them with you
Old Jul 24, 2008 | 10:40 AM
455rocket's Avatar
I would be suspicious that they weren't balanced right, a lot of people rush through it I was driving around with my new tires wondering why in hell i had a shimmy after just getting them balanced. Or else maybe a defect with one of the new tires.
Old Jul 24, 2008 | 10:46 AM
elecblue06's Avatar
yea when i got my rims on they just slapped some weights on the rim and didn't take off the brake clips.. they also through away the hub centric rings
Old Jul 24, 2008 | 12:54 PM
OrngBalt's Avatar
hence getting them road force balanced. they will tell you if a rim or tire is defective/out of shape. the computer will align the highspots of the rim with the low spots on the tire, or vice versa. Its honestly the best way to go.
Old Jul 24, 2008 | 04:00 PM
SushiCheffff's Avatar
just put on my wheels the other day, and am having the same problem. My wheels are brand new though, it didn't do it with my old stock wheels though? possible shitty balancing job?
Old Jul 24, 2008 | 04:05 PM
elecblue06's Avatar
did you install the wheels?
it can be 4 things
1. the brake clips weren't taken off
2. hub centric rings are needed
3. balance is outta wack
4. rim is fucked up
Old Jul 24, 2008 | 05:28 PM
k question for you. why would the brake clips need to be taken off? and where are they located(i know im a nubcake). Als0 i've got the hubcentric caps put on so that can't be it.
Ijust went to a wheel and tire service center and here is what they said.
If the vibration in the steering wheel and brake only occurs when im braking it is most likley that i over torqued my lugs putting to much pressure on them and warping the rotor. And also heres the best part. 300$ to repair. Now i got the money to get the service done, but that ******* SUCKS. Has ol boy gotten his fixed or found out what the deal is with his yet?
a quote from answers.yahoo.com describing the same thing tizzle and i are experiencing-------------------------------Resolved QuestionShow me another ť
My car is acting stupid?
Ive been told that my Brake Rotor might be going bad if it pulsates while im braking of hit a speed of about 25- 40 mph.What should i look for in a worn out brake rotor?
11 months ago
Report Abuse
by Mark in Time Member since:
July 23, 2006
Total points:
1179 (Level 3)
Add to My Contacts
Block User
Best Answer - Chosen
Best Answer - Chosen by Asker
The rotors might be warped. In some cars this can be caused by over-tightening the wheel lugs. Make sure they are torqued to manufacturer spec. If this doesn't help, have the rotors checked with a dial indicator (machinist tool). They may have to be turned on a lathe to make them true again.
While you're at it, check for excess play in the bearings.
Sometimes moisture in the brake fluid can cause pulsations. If you're redoing your brakes be sure to flush and replace the fluid.
11 months ago
Last edited by SushiCheffff; Jul 24, 2008 at 05:28 PM. Reason: Automerged Doublepost
Old Jul 24, 2008 | 06:00 PM
elecblue06's Avatar
if you're still under warranty the dealer should be able to resurface them
Old Jul 25, 2008 | 04:35 PM
yea my rotors were warped i got that fixed but im still having a problem with the tires while driving. ill take the brake clips off soon and im going to order the rings. but does anyone know how to check where theres a roadforce balancer around me? because at the dealer i got my brakes done at they said they didnt have one but they told me to get it done on one.
Old Jul 26, 2008 | 12:04 AM
Most chains should have it...I think the last time I saw it adverted it was a firestone.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
