Shifting issue
Old Jul 3, 2017 | 12:40 PM
blaknyellowSS's Avatar
Shifting issue
Just had my slave cylinder replaced (recently had a stage 3 ky clutch replaced a few weeks prior to that) and pedal itself is really stiff and needs more pressure to clutch in than normal...usually on sometimes takes a few to release back up which causes my clutch to slip until it hioks..any ideas what it may be?
Old Jul 8, 2017 | 05:09 PM
Old Jul 13, 2017 | 09:05 PM
the blurr's Avatar
Did this start to happen when you replaced the clutch, or just after the slave cylinder.
Old Jul 15, 2017 | 02:35 PM
Clutch was replaced first then the slave cylinder..since then it's been constantly like that..
Old Jul 15, 2017 | 03:37 PM
the blurr's Avatar
So if you put the clutch in and it was good, then you out in the slave and the pedal got hard, back track on what you did for the slave cylinder, could be a cheap slave or a crimped line
Old Jul 16, 2017 | 05:23 PM
I had it done at the dealership...would it need a re-bled?
Old Jul 16, 2017 | 06:06 PM
the blurr's Avatar
If it needed to be bled then the pedal would be spongy or would treturn, like it would stay to the floor, you have other issues
Old Jul 17, 2017 | 08:42 AM
royce777's Avatar
if the dealer did it then they should be warranting their work. take it too them.
