shudder
Old Sep 17, 2006 | 07:33 AM
zzzzzzzz's Avatar
shudder
hi guys. im getting a kind of noise or shudder in sterring when turning right like the power sterring is going bad . like theres a dead spot in sterring where its a little hard to turn
Old Sep 17, 2006 | 12:35 PM
zzzzzzzz's Avatar
ok then
Old Sep 17, 2006 | 12:39 PM
Matty's Avatar
Did you check the fluid?
Old Sep 17, 2006 | 12:40 PM
zzzzzzzz's Avatar
yes its good
Old Sep 18, 2006 | 07:03 AM
denniss's Avatar
What fluid did you check, the power steering is electric?
Dennis
Old Sep 18, 2006 | 12:21 PM
Matty's Avatar
Dennis
You are correct.
Old Sep 18, 2006 | 02:41 PM
bowtie_ss's Avatar
A bulletin came out for this about a week or so ago. Right now there is no fix for it, here is the bulletin #
Steering Column Shudder, Noise, Vibration While Making Right Hand Turns at 5-15 MPH (8-24 KM/H) (No Fix Available At This Time) #06-02-35-008B - (09/08/2006)
Old Sep 19, 2006 | 01:50 AM
zzzzzzzz's Avatar
ok great no fix well that sucks when i said i check fluid i meant i had oil changed and it says they did a ten point inspection brake fluid, power steering, ect
Old Sep 21, 2006 | 06:53 AM
denniss's Avatar
Here is the TSB
Document ID# 1861084
Subject: Steering Column Shudder, Noise, Vibration While Making Right Hand Turns at 5-15 MPH (8-24 KM/H) (No Fix Available At This Time) #06-02-35-008B - (09/08/2006)
Models: 2005-2007 Chevrolet Cobalt
2005-2006 Pontiac Pursuit (Canada Only)
2007 Pontiac G5
This bulletin is being revised to provide additional diagnostic information. Please discard Corporate Bulletin Number 06-02-35-008A (Section 02 -- Steering).
Condition
Some customers may comment on a shudder, noise or vibration that is felt through the steering column while making right hand turns at 5-15 mph (8-24 km/h). This condition can be duplicated by the technician. Removal of the 60 amp fuse that powers the EPS may eliminate the condition.
Correction
DO NOT REPLACE THE STEERING COLUMN.
Replacement of the steering column, P/N 10394224, is NOT recommended. Steering column replacement has been proven to be ineffective in several Technical Assistance cases.
Pull the 60 amp steering fuse (1) in the underhood fuse block. If this eliminates the shudder/vibration concern, contact Technical Assistance for further information in order to repair the vehicle. If this does not eliminate the shudder/vibration, continue to diagnose the vehicle according to the diagnostics in SI.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
DoMiStIc_RuSh_06
Mar 29, 2014 01:19 PM
cody.carr
Mar 24, 2013 01:21 PM
maliki778
Oct 19, 2010 09:40 PM
