so i got alot of problem help please
leaven work my car deside to crap out on me and here the codes it throw
-P0128 Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
-P0300 Random/Multiple Cylinder Misfire Detected
-P0335 Crankshaft Position Sensor A Circuit Malfunction
- P0336 Crankshaft Position Sensor A Circuit Range/Performance
-P0455 Evaporative Emission Control System Leak Detected (gross leak)
-P0496 Evaporative Emission System High Purge Flow
please help if u can tell me how to fix them it be great or what to do
He just listed the codes not what the problems are.
Need some symptoms to help !
The code could be all linked to a bad circut and untill I look at the prints I would not say for certain that they are all individual problems.
This is why I ask Did the all come up at once or Maybe he likes to drive around
With the service light on until there are a good half dozen codes to list!!
p0455 and p0496 probably your EVAP canister purge solenoid valve.
p0128 Thermostat is stuck open or the coolant temp sensor is buggered.
p0335 and p0336 Crank position sensor going bad or the wires from the pcm to the sensor are shorting some where.
