sputter when under load, please help!
Old Mar 25, 2012 | 02:30 PM
Ken5545's Avatar
I have a 2007 cobalt ss/sc, gm stage 2, 2.5 cat-back exhaust. put my stock intake back on. When i give it gas under a load it sputters and throws a dtc, p0171, system lean. i do not lose boost and have no vacuum leaks ( checked by using carb cleaner ). ive replaced the fual filter, maf senmsor, injector sleeves and o rings, clened throttle body, used injector cleaner. Tried about everything i could think of. Figuring its a fuel issue seeing how i dont lose any boost. Please help!! thanks!
Old Mar 25, 2012 | 03:34 PM
Coblasts's Avatar
Is the maf in the right way,arrow pointing in the direction of air flow?
As you said,all you did was put the stock air box back.
Check the air duct for the air box for a hole between the throttle body and the air box.
Old Mar 25, 2012 | 03:42 PM
Ken5545's Avatar
Yes, it's the right way. I've been messing with this car for the past couple weeks now.
Solaris99
28
Mar 15, 2017 01:22 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jrocstar
Sep 26, 2015 11:42 PM
jcarroll53
Sep 24, 2015 07:43 PM
