SS/SC Acceleration Problems
Old Feb 26, 2013 | 03:24 PM
t3lancer2007's Avatar
My problem:
The car loses speed while going up hill, to the point where I cant make it up a hill at highway speeds (65 mph). This isn't a steep hill, I live in Austin, Tx
I cant press the accelerator too hard or it will start losing performance and do the hill problem on relatively level highway.
I cant accelerate from a stop too hard or I run into the same problem.
I've been to three different Chevrolet dealerships trying to figure out what the issue was. The last dealership charged me 600.00 for replacing some vacuum hoses and told me it was fixed, but its not.
I'm low on funds right now and I have no idea what could be causing this.
My car is a 2005 Chevrolet Cobalt SS/SuperCharged with ~107k miles on it. This problem began 2 years ago and has begun getting worse and worse.
I've tried cleaning the throttle body but that didn't help at all. I have no idle problems. I do not misfire, I just lose power as if I'm trying to blow into a balloon that is full already.
Old Feb 26, 2013 | 03:31 PM
jonathan923's Avatar
what does your boost gauge read on wot throttle? sounds like a clogged cat gone real bad
and 600.00 for vacum hose, dear god!? rape
Old Feb 26, 2013 | 03:33 PM
zrated89's Avatar
ive seen and fixed issues where the gas pedal assembly loses communication with the throttle body assembly and can cause this as well
Old Feb 26, 2013 | 03:35 PM
Yeah, it was pretty bad, I had to have my car towed to the dealership. The dealership did something to my boost gauge and it hasn't worked since, but I never had time to go back since I'm working and in school.
Originally Posted by zrated89
ive seen and fixed issues with the gas pedal assembly loses communication with the throttle body assembly and can cause this as well
What was the fix for this?
Old Feb 26, 2013 | 03:41 PM
Twoozofjuice's Avatar
my car would start bogging at around 80 or so and i figured it was some type of restriction. turns out intake was being crushed in the part where it goes down to the fender...damn the dealership owned you man....
Old Feb 26, 2013 | 03:42 PM
turbosmart4's Avatar
I went through something siimilar..ended up being the catalyc converter being clogged.
Old Feb 26, 2013 | 03:45 PM
How would I be able to tell if its my cat?
zrated89's Avatar
as said see what your boost is reading first, if its excessive assume its the cat. The tech2 scanner at the dealer can verify if the pedal sensor is synced with the throttle body and for as much as they raped u for i hope they did that. Typically youll set a CEL for both the cat and the issue i described though. Ive even seen the cars go into limp mode because of both
Old Feb 26, 2013 | 03:46 PM
I dont get any CELs.
Old Feb 26, 2013 | 03:51 PM
Ever changed the fuel filter, spark plugs, and intake filter?
Any coolant loss ?
Old Feb 26, 2013 | 03:53 PM
Does ur clutch slip/
Old Feb 26, 2013 | 03:56 PM
Yes they all have been replaced, no clutch slippage. I'm searching for a way to hook my boost gauge back up. If anyone has a link, it would be greatly appreciated.
Old Feb 26, 2013 | 04:47 PM
Seriosly sounds like badbcat
Old Feb 26, 2013 | 04:51 PM
zrated89's Avatar
stock boost gauge is electric with one connector on the A pillar not hard man
And to hook up the gauge u need to remove the pillar and get the wire
Old Feb 26, 2013 | 04:55 PM
zrated89's Avatar
i would hope he comprehended what i said lol if not sell the car !!
Old Feb 26, 2013 | 05:00 PM
I'm not new to modding cars. I had a t-28 on my 2003 Lancer O-Z Rally with intercooler, full coil overs, and a bunch of other stuff, I just chose not to do anything to this car.
But alas, I've gone to meineke and it is my cat. I now need to look for a replacement aftermarket piece as the stock piece is $900.00
Thanks everyone for the help in diagnosing my problem.
Old Feb 26, 2013 | 06:14 PM
sLAsh's Avatar
Get a catted dp from zzp and u are good to go
Old Feb 26, 2013 | 07:24 PM
Gelladuga69's Avatar
Find the stock one here in parts for $80 shipped to your door.
Old Feb 26, 2013 | 08:06 PM
zrated89's Avatar
no doubt i sold mine for 50$ lol
Old Feb 26, 2013 | 08:09 PM
nhanson's Avatar
Might as well get a header and downpipe combo now
Old Feb 26, 2013 | 08:15 PM
900 for a stock cat.... Bro they are selling u a complete header/downpipe/exhaust kit.
Call gm and give them ur vin. In some states they wwill replace ur downpipe free of charge if it has gone bad before 130k miles.
Old Feb 26, 2013 | 08:16 PM
Ur a lucky bastard if u live in austin TX cuz tx will replace it free of charge.
Old Feb 26, 2013 | 08:24 PM
zrated89's Avatar
i wana say our cats are covered up to 100k with the emission laws no more could even be 80k
Old Feb 26, 2013 | 09:07 PM
I spoke with the Chevrolet dealership and they said they'd replace it up to 120k miles if that was the problem. I go to see them at 11 am tomorrow.
