stage 2 problem help fast
Old May 24, 2010 | 06:17 PM
bbbevans89's Avatar
Unhappy stage 2 problem help fast
i installed 42's and 2.9 and got a trifecta tune and now my car wont start id did for a bit and it idled really rough and shut off now it wont start at all. i used the old harness is this aloud does it not give it enough power im throwing a fuel pump primary circuit code now
Old May 24, 2010 | 06:21 PM
chris88z24's Avatar
Check fuse for fuel pump, and all fuses for that matter. You could have shorted something when you swapped ECM's (assuming that's what you did).
Old May 24, 2010 | 06:25 PM
evil ss's Avatar
How long did the car run for b4 it shut off and does the security light stay on?
Old May 25, 2010 | 05:16 PM
bbbevans89's Avatar
fixed aparently gm made 3 rows and only 2 rows can be used for the fuel pump relay so yea im good and the cold air came loose thats why it was rough idle
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
