Starting issue; battery?
Old May 18, 2011 | 04:13 AM
Clifton's Avatar
I own a 2010 2LT coupe with almost 20k. The last 4 times once in a blue moon, I start her up, hear a few clicks, CEL luminates then goes away, car starts like normal while gauge (gas/Rpm) needles flicker at the bottom before resuming position. Car runs fine afterward. Could this be battery related? Ignition; Fuel pump?
My dad's 2004 Ford Taurus had this issue before only she would crank not start. When after start gauges flicker. Thought it be the programmed keys goin bad but Turned out to be the battery.
Old May 18, 2011 | 07:37 AM
Coblasts's Avatar
You have warranty ,bring it to the dealer.
But for a quick check look at the battery connections they could be loose,also the batery gound to the car body.
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
