startup creeking vid
Old Nov 28, 2007 | 01:41 PM
yapster's Avatar
when i startup the car after sitting overnight it makes that sound. after a couple of minutes, i drive the sound goes away. anybody else have this?
http://s218.photobucket.com/albums/c...t=MVI_0869.flv
Old Nov 28, 2007 | 01:47 PM
D4u2s0t's Avatar
probably because it's cold. makes sense since it goes away once it's warmed up.
Old Nov 28, 2007 | 02:16 PM
CTCOBALTSSS's Avatar
Damn man. I haven't stood next to any Cobalts that sound like that. Sounds like something needs lube.
I don't know bro but good luck with it.
Bump for the man.
Old Nov 28, 2007 | 03:43 PM
RedlineBrian's Avatar
That doesn't sound good. Is your belt on all of the pulleys straight? Maybe the bearing in the idler pulley needs some grease?
Old Nov 28, 2007 | 03:45 PM
bgbearcatfan's Avatar
get some wd40 and starting spraying like crazy
Old Nov 28, 2007 | 04:09 PM
07hhr's Avatar
sounds like a bearing my cavalier did this and 3 days later the water pump went out.
Old Nov 29, 2007 | 01:23 AM
Mr_Slobalt's Avatar
take high grit sandpaper to the outside edges of the belt if it's frayed (while running...watch your fingers)
if not, it might just be a pulley
Old Nov 29, 2007 | 09:58 AM
mugencivicsi's Avatar
Sounds like the tensioner, take it to dealer
i have had somehwat same noise twice..
the tensioner is oil pressure based, when its cold it takes a bit for it to go away...
i have already had 2 new tensioners put in, at the same time, it it has been going on for a while, (my chain marked up the block a bit)
dealer replaced tension (2times) and the chain (once)
Old Nov 30, 2007 | 05:54 PM
yapster's Avatar
update: yup, dealer replaced the timing chain shoe tensioner no more creeks. also fixed that rear seat pivot squeaks. hey mike still selling the car?
Old Nov 30, 2007 | 06:03 PM
dont know.... I lease the car, but if someone walked up to me and asked to take over lease, (id say pay transfer cossts, and you got it)..... orhter then that, its going back after lease is up, and im getting a 2008-2009 GMC Sierra Crew Cab 4x4.....
need something to tow my off road toy around.....
Old Nov 30, 2007 | 06:09 PM
Kaisoboy's Avatar
Spray some dry silicon lube on the belt and see if it goes away. If it does then you know it is the belt rubbing on something. If it does not go away then it is a bearing on one of the pullies, probably the tensioner.
Mine was doing that also after the stage two was installed. what might be happening is that they did not align the pulley and the pulley is off by a hair. so if you dry lube the belt and the sound goes away that is probably what has happened. Just take it in and have the pulley re-adjusted.
cheers and hope this helps
06blackg85ss
83
Jan 18, 2017 04:35 AM
cw383
Sep 3, 2015 11:16 AM
JonyyB
Oct 6, 2005 11:06 AM
Drewsrt
Apr 20, 2005 03:01 AM
