Steering wheel gets hard when turning
Old Jan 5, 2014 | 12:13 PM
JBullard's Avatar
Question Steering wheel gets hard when turning
Does anyone know what could be the problem when my steering ? when I turn corners at regular speeds the steering wheel gets hard and sticks in the position its in. Im pretty sure the power steering recall was done by the previous owner of my car.
thanks ijn advance to anyone who helps!
Old Jan 5, 2014 | 02:28 PM
jp1600's Avatar
Good god i told you on fb. Steering gear rack. Its gummed up to ****. Same thing happened to me.
Old Jan 5, 2014 | 02:50 PM
JBullard's Avatar
Haha I don't think that was me on Facebook. Thanks a lot tho. How do I clean it out?
Old Jan 5, 2014 | 02:51 PM
Sox-Fan's Avatar
Got Brakes?
Or ball joint, or strut bearing.
Is it making noise? jacked it up and looked it over?
Old Jan 5, 2014 | 04:45 PM
JBullard's Avatar
No noises. I haven't really been able to jack it up because it's winter. I'll just have to bring it to the shop. I find the car shakes a bit when I'm on the highway tho. It might be unrelated too
Old Jan 5, 2014 | 05:08 PM
ae_xiong's Avatar
I'm starting to experience this too. Lol
Old Jan 5, 2014 | 06:15 PM
jp1600's Avatar
Jack the car up, shake the wheel side to side, any play is bad, replace it
Old Jan 5, 2014 | 07:33 PM
ae_xiong's Avatar
I have no play so I doubt mine will be due to ball joints. Maybe its the steering gear rack u guys r talking about. How would I clean/replace it? Sorry if I'm stealing your thread op but I've got the same issue too. Lol
Old Jan 5, 2014 | 07:34 PM
qwank's Avatar
check the u joint on your steering shaft
Old Jan 5, 2014 | 07:38 PM
ae_xiong's Avatar
Would I need to replace it or just clean it?
Old Jan 5, 2014 | 11:40 PM
jp1600's Avatar
Replaced, check for play, it feels just like a bad ball joint
Old Jan 6, 2014 | 01:17 AM
ae_xiong's Avatar
Damn, the list never ends! LOL Always gotta replace one thing after another on these cars. Such poor build quality.
Old Jan 6, 2014 | 10:11 AM
Sox-Fan's Avatar
Got Brakes?
are you serious?
so, you're saying that this cheap ass car should never wear out? that more expensive cars don't wear?
you got what you paid for. deal with it.
Old Jan 20, 2014 | 02:40 PM
JBullard's Avatar
My mechanic said due to the cold weather -30 c° and moisture getting in my car from snow on my shoes, moisture gets in the power steering sensor and it doesn't know where the steering wheel position is and doesn't know when to help...
Old Jan 20, 2014 | 03:02 PM
Whitnith's Avatar
These cars are beginning to push 8 or 9 years old... Things wear out, if you don't want to deal with it never keep a car more than maybe 5 years.
You would maybe have a case if you have an 08 or 09, but seriously? It's an econobox.
To be back on topic, consider your alternator. It seems like the power steering is one of the first things to go when the alternator isn't working at full power. It can be sticky at corners, especially if you've been driving a lot, or if the car has been sitting awhile.
Old Jan 25, 2014 | 01:27 AM
white07's Avatar
I have this exact problem, the wheel doesnt come back out of the turns so easily any more and feels heavy while in the turns.
My car did sit for a day when the weather was like -35C over here. today went to start it up, felt fine for the first 4 km, then I started to notice a difference. hasn't gone away yet.
I have no idea what it could be. have you solved yours yet? do u have any warning messages or CELs? because i don't.
Old Mar 4, 2014 | 11:29 AM
1BadBlueSS's Avatar
Mine has the same issue, Any fix?
Old Mar 6, 2014 | 11:22 AM
1BadBlueSS's Avatar
I fixed mine by spraying PBB blaster on the steering ujoint and let it sit all day. Got in it to drive home from work and it was back to normal.
Old Mar 6, 2014 | 12:15 PM
05g5's Avatar
Band aid fix
It will come back
Old Mar 16, 2014 | 02:14 AM
white07's Avatar
it's been a while, just thought I would post my solution. It was the U joint, the entire intermediate shaft had to be replaced. The U joint was seized in one position, so it felt like i was turning the steering wheel in chunks. New intermediate shaft did the trick!
Old Oct 21, 2019 | 05:52 PM
Hillmer Rod's Avatar
Did you ever figure out what this issue was have the same problem
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
