Stock clutch questions.
Old Jan 19, 2007 | 04:22 PM
LSJFury's Avatar
I got a 2006 SS S/C non-G85 3 or 4 weeks ago, and so far it's been a real pleasure. No problems yet, and this isn't really a problem (I'm hoping).
Any SS S/C owners notice that their clutch has a fairly large dead-spot before it engages? For example, with the clutch pushed in all the way, as you let it out there's (estimation) about 3-4 inches of travel before the clutch begins to catch. It's like it doesn't start to catch until the pedal is about half-way out?
It does engage progressively and fairly hard as I expect, it held very well under the 2 or 3 hard launches I've done with it, and by the time the pedal is all the way out the clutch has definitely fully engaged before the end.
Anyone else have this?
It's hard to make smooth take-offs, smooth shifts, and even harder to shift quickly when your clutch doesn't even catch until it's half way out. Just hard to predict. I'm used to the way the clutch in my last car (Cavalier Z24) worked where there was only maybe 2" of travel when letting the pedal out before it began to catch.
Is this a problem? Is the clutch getting worn out already @ only 11,000 miles? Is it a problem with the master/slave cylinders? Can the Master/Slave cylinders be adjusted to make it catch sooner?
Thanks in advance!
Old Jan 19, 2007 | 04:25 PM
CTCOBALTSSS's Avatar
You clutch is OK. Our cars are not the easiest manual to drive I think everyone who has driven other manual cars will agree. It's tough to be smooth.
There actualy is a fix to the stock clutch problem. Here is what was found in a nut shell.
These stock clutches are capable of 300whp. The problem is people aren't shifting at high enough RPMs. You should be shifting around 3,000rpm for normal daily driving. That's what these clutches like. Most people shift around 2,000 or 2,500 rpms all the time and believe it or not that actualy causes the clutch to slip and create a varnish on the disc which creates slipage. We think we are being nice to the car but it hurts the clutch. If you start shifting around 3,000 or even 3,5000 rpm all the time the varnish goes away and the clutch grips like crazy. Here is the write up.
https://www.cobaltss.net/forums/drivetrain-79/how-make-your-clutch-stop-slipping-find-out-inside-36130/
I have been doing this lately and I have to say it works wonders.
Old Jan 19, 2007 | 06:14 PM
calchr2's Avatar
interesting. i shift about 2,500 almost every time going from 2nd to 3rd. from 1st to 2nd, its usually about 3,000 to 3,500.
Old Jan 19, 2007 | 07:37 PM
slacker's Avatar
That is where it should be Just installed after Clutch masters clutch and you want the pedal 2-3" from floor so it will disengae completely. everyone who installed had disengagement problems until the system is bleed the proper way. So don't worry it's fine. but don't granny shiftall the time.
Old Jan 19, 2007 | 07:40 PM
LSJFury's Avatar
https://www.cobaltss.net/forums/showthread.php?t=36130
That's really interesting. I thought I've just been being all nice and stuff to my new car by shifting @ 2500 all the time. I figured that since I just bought the car that I'd go really easy on her for a while before letting her rip, but I guess there's no problem shifting at 3000-3500... I'll give that a try tonight and tomorrow and see how she does. Thanks
Old Jan 19, 2007 | 07:51 PM
slacker's Avatar
Know worry this motor likes to twist I'm set at 7250 rpm redline your just starting to wake it up.
Here is my list of performance mods so far hope to have NX kit installed in about 2weeks.
Performance Mods
1)GM Performance - exhaust manifold, Sport cat-back exhaust,Stage 1&2 upgrades
2) 2.8" Pulley
3) Injen Cold Air intake
4) Custom Progressive Methanol Injection system by Alkycontrol.com (Sponsor)
5) HP Tuner reflash and dyno tune
6) B&M Shifter
7) Inglis engine dampener
8) Clutch Masters Stage4 Clutch & pressure plate (Sponsor)
9) Clutch Masters Aluminum flywheel (Sponsor)
10)H& R springs
11)Aluminum Strut Bar
Old Jan 20, 2007 | 09:11 AM
joes407's Avatar
stage 2 fixed that whole hesitation thing for me.
Old Jan 20, 2007 | 09:41 AM
mattyfinch's Avatar
Performance Mods
2) 2.8" Pulley
6) B&M Shifter
10)H& R springs
Your running straight methanol huh? i run an 80 meth 20 water mixture, but with that much you should be running a 2.6" pulley friend!, and add some massive timing!
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
