strange clunk
Old Jan 24, 2013 | 05:36 PM
SFCobaltSS's Avatar
strange clunk
ok so maybe it's more of a clack sound. I hear it when I am in gear, usually around 2-3500 rpms, and its only when I tap the gas pedal. I was originally thinking clutch, but it can't be because it's not slipping when I punch it. any ideas or similar experiences?
Old Jan 24, 2013 | 06:19 PM
buildmeanempire's Avatar
I just had my tranny replaced and it did that going to second and gave it gas. They said the bearings were worn out. Slighty different from your issue but may be the same thing.
Old Jan 24, 2013 | 10:32 PM
sLAsh's Avatar
Motor mount?
Old Jan 24, 2013 | 11:48 PM
Do u feel ur engine rock back and forth? Or is it kind of a crashy sound? If its a clashy sound its just the clutch
Old Jan 25, 2013 | 01:08 AM
SFCobaltSS's Avatar
I'm not sure if you mean wheel bearings, but if so then maybe I should change the hubs. As for the mounts, I put some ottp tranny mounts so it's not that. I do keep cracking my flex pipe, it's not the original one either.
any help?
Old Jan 25, 2013 | 01:17 AM
There are bearings in the tranny. If your wheel bearings are bad it would be a constant vibration sound. But now that you mention it, it could be the flex pipe. Others on here say the gm flex pipe is garbage and will constantly break.
Meadowvalien
Aug 17, 2017 06:32 PM
jcarroll53
Sep 24, 2015 07:43 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
Sean Cummings
Sep 11, 2015 09:35 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
