Strange issue after 3rd LED brake light install
Old Aug 7, 2012 | 10:43 PM
breds2k's Avatar
Just installed my LED 3rd brake light. Went to tap the brakes and only the LED blinked not the tail lights.
I turned the headlights on, and my DRLS come on but still brake lights wont work. Just spent an hour search the forums, checking fuses, checking all wiring getting really pissed and was about to freak out.
Then I put the key in the ignition and turn on the ACC mode, hit the brakes and all brake lights function properly!!! WTF?
Any insight here? Brake lights always worked when the cars off before, do i need a resistor or something?
And i wouldve searched this but this god damn forum is so laggy I cant figure out why, tried on 3 different computers TERRIBLE search response time and laggy scrolling that takes forever!
Old Aug 7, 2012 | 10:55 PM
iToastie's Avatar
Are your taillights both LEDs? If not, it could be because you don't have a resister on the 3rd brake light LEDs.
I don't know why it would be that, but it seems like the only logical explanation.
Old Aug 7, 2012 | 10:57 PM
RandyO's Avatar
Also, if your car is equipped with cruise control it probably wont work either because you need a resistor for the 3rd brake light bulbs when you switch to LED. Weird chevy problems. lol
Old Aug 7, 2012 | 11:07 PM
breds2k's Avatar
no cruise control, stock break light bulbs.
Old Aug 7, 2012 | 11:10 PM
chood711's Avatar
did you leave one of the stock bulbs in?
Old Aug 7, 2012 | 11:41 PM
LtDanBoostdG5GT's Avatar
You might have a bad electrical connection somewhere.... or bad ground.... I have not had any problems with my retrofit so far.... I hope its not in the electrical under the floors that would suck :/ Maybe a Fuse? or Loose Wire?
Old Aug 7, 2012 | 11:49 PM
breds2k's Avatar
gaurenteed this will be fixed if i get LED brake light bulbs, the LED 3rd brake is coming on faster than the tails so maybe thats screwing it up.
Old Aug 7, 2012 | 11:59 PM
Stamina's Avatar
Diagram for a 2007 Cobalt
Old Aug 8, 2012 | 02:24 PM
iToastie's Avatar
It's probably just the need of a resistor. If you get LED brake light bulbs and they still dont work, get resistors for them too.
Old Aug 8, 2012 | 02:31 PM
68nova200's Avatar
This is actually a stock thing that is normal. when the car is OFF and you press the brakes ONLY the center light comes on. when the car is on ALL lights function normally.
I can post a video of this when i get home.
/thread
Old Aug 8, 2012 | 03:13 PM
LS6Rally's Avatar
^ This, wow i thought more people knew this. its normal, once the key is turned from the off position, all brake lights work as normal.
The CC issue is only on 07+ IIRC. my 06 Doesnt have it
Old Aug 8, 2012 | 03:18 PM
mkulrey13's Avatar
Thats how the car works...
/thread
Old Aug 8, 2012 | 05:13 PM
kzak104's Avatar
My brake lights don't work when the car is off :/ 09 ss
Old Aug 9, 2012 | 11:01 AM
how did it plug in? and did you leave the bulbs in the other two slots?
Old Aug 9, 2012 | 02:31 PM
breds2k's Avatar
i got the kit from buy hids, just went in with two pins, didnt touch stock tails.
Very strange that this is how they work couldve sworn theyve lit up before when the key is not in.
Old Aug 27, 2012 | 04:10 PM
BlackLsCoupe's Avatar
need how to on this i set mine in there and it flops around did you glue it?
Old Oct 7, 2012 | 11:18 AM
Sox-Fan's Avatar
Got Brakes?
Bump.
Breds how the heck did you attach that circuit board into the tail light housing? there are no instructions or mounting parts and it isn't immediately obvious to me.
Old Oct 7, 2012 | 02:23 PM
breds2k's Avatar
tape bro!!! just rolled circles of it. sits there fine!
Old Oct 7, 2012 | 02:39 PM
DFZ24's Avatar
Why people says this????????
I have cruise control and did not use resistor for led 3rd brake light. And my brake taillights are led with resistors. And everything works fine as it should... and yes my cruise control works.
Old Oct 7, 2012 | 02:42 PM
DFZ24's Avatar
There is like 2 how to's with pictures.....
Old Oct 7, 2012 | 02:48 PM
Sox-Fan's Avatar
Got Brakes?
I found one, which was drill a couple of holes and zip tie it. Did you find a different one?
Old Oct 8, 2012 | 01:26 AM
DFZ24's Avatar
i did the double side tape, i dont like to drill on parts lol
drilled
https://www.cobaltss.net/forums/how-...ht-led-201699/
https://www.cobaltss.net/forums/how-...version-27113/
mine on page 3:
https://www.cobaltss.net/forums/how-...13/index3.html
Old Oct 8, 2012 | 09:41 AM
Sox-Fan's Avatar
Got Brakes?
Awesome, thanks a bunch!
Old Oct 8, 2012 | 09:44 AM
post pics of setup
Old Oct 8, 2012 | 01:16 PM
Sox-Fan's Avatar
Got Brakes?
I will when I finally get to work on mine. Won't be fore 2 more weeks now.
