stundering wipers PLEASE HELP!!!!!
what the heck is up with my windsheld wipers?
I got my car new at the new of 2006 and every time it rains the driver side wiper studers and jumps and just does not wipe smooth. Sometimes its better then others but it doesn't matter if its raining hard or soft I've tried using rainX and that made it worst. I've put new wipers and that olny works for about one rain or so. And its just about to drive me craze. It is really getting to me and the studering is bad you cant even stand to drive the car. I do keep my car very clean I try to hand wash once a week if I can, and I do wax once or so a year. LIke I've said I have tried EVERYTHING to fix this and cant seem to make anything keep this promble from coming back. Someone please help me fix this or tell me that there is something to do about it. thanks
^ NO! rainX makes it MUCH worst, I dont uderstand I've clean off all the wax and rain x it does it, put new rain x on it does it, the only time its not bad is when the car is REALLY drity then it just dont wipe water its just moving across the window?? I'm to the piont were I just want to smash in the windsheild and rip off my wipers and just say the hell with it its that bad, and been going on for almost 2 years.
It appears you need to read the posts you reply to...
To the op....as pointed out above, make sure you have the windshield very clean, no wax or other stuff on the glass. Same for the blades, give them a rub down with rubbing alcohol. Get a decent set of blades, the $1.99 ones are not worth the package they are in.
I put a set of reflex blades (Canadian Tire) on, and while they cost a bit (about $30.00 for 2 iirc) they actually work pretty well.
Don't know if there are any adjustments for the tension on the wiper arm (my 535 has a screw that lets you adjust tension) but a little "brute force" adjustment may help.
I got my car new at the new of 2006 and every time it rains the driver side wiper studers and jumps and just does not wipe smooth. Sometimes its better then others but it doesn't matter if its raining hard or soft I've tried using rainX and that made it worst. I've put new wipers and that olny works for about one rain or so. And its just about to drive me craze. It is really getting to me and the studering is bad you cant even stand to drive the car. I do keep my car very clean I try to hand wash once a week if I can, and I do wax once or so a year. LIke I've said I have tried EVERYTHING to fix this and cant seem to make anything keep this promble from coming back. Someone please help me fix this or tell me that there is something to do about it. thanksI put a set of reflex blades (Canadian Tire) on, and while they cost a bit (about $30.00 for 2 iirc) they actually work pretty well.
I just got some bosch EVO's or icon they are the same thing, they were like $18 each, the best ones at autozone, they work great ONE TIME
Last edited by philupondes; Dec 11, 2008 at 12:11 PM. Reason: Automerged Doublepost
i've also had this problem. had it since i bought the car off of the showroom floor. changed to rainx blades and it barely made a difference. still have the problem occasionally.
just use rain x and dont use your wipers thats what i do and i dont ever use my wipers most of the time so they last longer and dont wear out!!
^ yea then it feels like you are triping ***** when it rains. **** it I've really think I may trade after xmas, a stelership down the road has a 07 ss/sc with 16k asking $14999, but I may be able to talk them down a little bit.
plain and simple.......cobalt windshields and wiper arm setup are just ****.......windshields are not the right angle and the wipers are not centered well enough to have even pressure on either side......just plain suck so get use to it.......i did..........HAHAHA......Later.
exactly. u can replace all the blades u want, its most likely your actual arm though, not the blade. i kno my drivers side drives me ******* crazy. over 75% of the time i use my wipers it likes to be a bitch and not run smoothly. i dont have any problems with the passenger side though.
