Synchro problem?
Old Nov 7, 2008 | 10:32 PM
flash13brandon's Avatar
Synchro problem?
Occasionally it seems like i hit a wall when i try and shift from 1st into 2nd...i read where it is a synchro problem? Can someone verify this? and will the dealership fix it under warranty?
Old Nov 9, 2008 | 03:55 AM
Zander916's Avatar
Having come from an Acura RSX-S I know they had HUGE problems with the exact same thing. They even got a petition together for it.
In that case and I'm sure this is the same. It was indeed the synchros and quite a few people took it to the dealer.
Many of the dealers did replace synchros but the problem persisted. Myself I tried different fluids - Royal Purple, Amsoil... and it did little. The biggest improvement I had was replacing the motor mounts with stiffer ones.
Old Nov 9, 2008 | 11:40 AM
So do you think i should take it to the dealershipn or is that pointless?
Old Nov 9, 2008 | 12:02 PM
xxxxsh4d0wxxxx's Avatar
Welcome to my world.
I've had this problem since a few months after I got my Cobalt.
I hear about it from multiple people though, so it's not just your car.
It is annoying as hell though, 1st to 2nd shifts are so crappy because of that wall; it makes launches a bitch for me.
Oh well, just rip it into gear harder I guess; hell if I care, there are warranties for a reason.
Old Nov 9, 2008 | 12:38 PM
Ya tru bro. How often does it happen to you?
Old Nov 9, 2008 | 01:03 PM
chevysssc's Avatar
its the shift linkage pin.aka roll pin i had the same issues, it self destructs when you miss a shift, and makes for sloppy shifting, hard shifting, and prevents the car from going into gear sometimes. mine was covered under warranty. good luck, its a very common problem it prevents you from grenadeing your trans
Old Nov 9, 2008 | 01:32 PM
Don't know about the OP, but for me it happens about 98% of when I shift 1st to 2nd.
That's good.
Now I can go in the dealership and bitch.
Hurray for warranty work!
Old Nov 9, 2008 | 02:06 PM
So once they fix it...what will cause it to go bad again?
Old Nov 9, 2008 | 02:57 PM
chevysssc's Avatar
no as long as you dont miss a shift
Old Nov 9, 2008 | 03:40 PM
So everytime you miss a shift it breaks the pin?
Old Nov 9, 2008 | 05:21 PM
red06SC's Avatar
I'm going to the dealer tomorrow.. I grind out of 2nd sometimes, especially after light engine braking in 2nd, also it is scratchy and grinds while engine braking.
Old Nov 9, 2008 | 05:25 PM
I get that all the time.
Old Nov 9, 2008 | 05:50 PM
That sucks man. The only problem I have is OCCASSIONALLY there is a wall from 1st to 2nd. Is this the same problem you'll are talking about except mine isnt as bad yet?
Old Nov 10, 2008 | 02:04 AM
Yeah, I always get a constant wall.
Well, 98% of the time anyway.
I really couldn't care less because it's going to be snowing in less than a month, but I'd like it fixed by the beginning of next year.
Old Nov 10, 2008 | 02:11 AM
chris88z24's Avatar
LMAO. No... if the pin is broken you won't be able to shift at all.
Old Nov 10, 2008 | 08:33 AM
Well that other guy said that with a broken pin, it presents that wall and sloppy shifting
Old Nov 10, 2008 | 09:29 AM
PhantomSS's Avatar
synchro = grinding going in gear
linkage cables = wall, sloppy shifting, very very occasional grind
fix the linkage cables and keep them tight so you dont get the dreaded grinding problem and need to replace the trans. 110.00 not covered under warranty but worth it.
I do it once a year.
Old Nov 10, 2008 | 12:32 PM
Originally Posted by PhantomSS
fix the linkage cables and keep them tight so you dont get the dreaded grinding problem and need to replace the trans. 110.00 not covered under warranty but worth it..
Not under warranty, huh?
We'll see how quickly that changes when I walk in those doors.
Haha.
My dealership hooks it up anyway, so it shouldn't be a problem.
Old Nov 10, 2008 | 12:36 PM
06BrandonSS's Avatar
I get this sometimes too, causing me to miss the gear. I grind going into reverse about 50% of the time too, keep meaning to get under and check the roll pin. Good luck at the dealer.
Old Nov 10, 2008 | 01:22 PM
Zander916's Avatar
Haha.
I think he was talking about $110.00 once a year as preventative maintenance.
Old Nov 10, 2008 | 11:09 PM
SSnAZ's Avatar
Is there a synchro on reverse? I too get a THUD every once in a while (1 2 shift) and noticed it today in a parking lot. I realized i was also pulling back into gear too soon and not holding in the clutch long enough. What kind of Lucas or Royal oil does the SS manual tranny take?
Old Nov 11, 2008 | 01:27 AM
I believe it's 75w-90 max lube for the Royal Purple
Old Nov 11, 2008 | 04:09 AM
cobaltssredtint's Avatar
the reason why there is a wall is because the huge difference in ratio of 1st and 2nd...you will notice if you in 1st and shift at 3500 or 4000rpms...its a smooth shift from 1st to 2nd...also it might be because you don't let the rpms drop enough when you let go of the clutch
Old Nov 11, 2008 | 11:24 AM
I'm talking about a wall just sitting at a redlight and trying to put it in gear to take off...
Old Nov 11, 2008 | 12:29 PM
PhantomSS's Avatar
i pay 110.00 a year for the linkage cable tightening as preventitive maitenance. The cables are considered wear and tear.
