tc light on
Old Dec 3, 2010 | 09:48 AM
snowman65's Avatar
tc light on
2006 ss 2.4 nonsupercharged. Traction control light stays on all the time. Shifts very hard. I replaced the intake/exhaust camshaft position sensors. No change. Also throwing code p0107. Any help would be appreciated.
Thanks
Old Dec 3, 2010 | 10:13 AM
blackrocky's Avatar
P0107 MAP/Barometric pressure circuit low input........just generic code though.
Old Dec 5, 2010 | 12:36 PM
snowman65's Avatar
wheel speed sensor
Thanks for the reply. Does this mean that I need to replace the sensor? Are there things I can check before I replace? As far as the tc light, does anyone know about changing the wheel speed sensor? Is this something that could be causing the tc light to stay on?
Old Dec 13, 2010 | 02:53 AM
Cptnsweet's Avatar
I had that problem with my 06 SS non supercharged cobalt. i think it was my abs module or traction control module going out. my check engine light would come on then go off as well, and the car would shift really hard and just run like **** if you go to auto zone or advance auto parts they will check the code for free and tell you what the problem is thats where itook my car
Old Dec 13, 2010 | 08:23 AM
insylem's Avatar
If your wheel speed sensor is going out.....
I think you'd get an ABS light as well....
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
