those with p0455, quick warning
My 07 has been throwing this code for a while, along with the "check gas cap" message on the DIC. Took it into the dealer today and they did a smoke test and found no leaks. Apparently there is a reflash out because many cobalts are throwing the code with no leaks. Just a warning, if you are running an aftermarket tune, DON'T let them reflash it! Luckily I knew my tech and he didn't flash it, he replaced the gas cap for me to see if that will fix it. Just a heads up for you guys
xTooltipElement
Service Information
2006 Chevrolet Cobalt | Document ID: 1528420
DTC P0455
System Description
The control module tests the evaporative emission (EVAP) system for a large leak. The control module monitors the fuel tank pressure (FTP) sensor signal to determine the EVAP system vacuum level. When the conditions for running are met, the control module commands the EVAP canister purge solenoid valve OPEN and the EVAP vent solenoid valve CLOSED . This allows engine vacuum to enter the EVAP system. At a calibrated time, or vacuum level, the control module commands the EVAP canister purge solenoid valve closed, sealing the system, and monitors the FTP sensor input in order to determine the EVAP system vacuum level. If the system is unable to achieve the calibrated vacuum level, or the vacuum level decreases too rapidly, this DTC sets.
The following table illustrates the relationship between the ON and OFF states, and the OPEN or CLOSED states of the EVAP canister purge and vent solenoid valves.
Control Module Command
EVAP Canister Purge Solenoid Valve
EVAP Canister Vent Solenoid Valve
ON
Open
Closed
OFF
Closed
Open
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P0455 Evaporative Emission (EVAP) System Large Leak
Conditions for Running the DTC
• DTCs P0068, P0069, P0095, P0096, P0097, P0098, P0106, P0107, P0108, P0112, P0113, P0117, P0118, P0120, P0121, P0125, P0128, P0130, P0131, P0132, P0133, P0134, P0135, P0136, P0137, P0138, P0140, P0141, P0220, P0442, P0443, P0449, P0452, P0453, P0496, P0502, P0562, P0563, P0641, P0651, P1133, P1134 are not set.
• The engine is running.
• The ignition voltage is between 10-18 volts.
• The barometric pressure (BARO) is more than 74 kPa.
• The fuel level is between 15-85 percent.
• The start-up engine coolant temperature (ECT) is between 4-65°C (39-149°F).
• The start-up intake air temperature (IAT) is between 4-75°C (39-167°F).
• The start-up ECT and IAT are within 8°C (16°F) of each other.
• DTC P0455 runs once per cold start drive cycle once the above conditions are met.
Conditions For Setting the DTC
The EVAP system is not able to achieve or maintain vacuum during the diagnostic test for up to 13 minutes.
Action Taken When the DTC Sets
• The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
• To help locate intermittent leaks, use the J 41413-200 Evaporative Emissions System Tester (EEST) to introduce smoke into the EVAP system. Move all EVAP components while observing smoke with aJ 41413-SPT High Intensity White Light. Introducing smoke in 15-second intervals will allow less pressure into the EVAP system. When the system is less pressurized, the smoke will sometimes escape in a more condensed manner.
• A temporary blockage in the EVAP canister purge solenoid valve, purge pipe or EVAP canister could cause an intermittent condition. Inspect and repair any restriction in the EVAP system.
• To improve the visibility of the smoke exiting the EVAP system, observe the suspected leak area from different angles with a J 41413-SPT .
• Reviewing the Failure Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
• For intermittent conditions, refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
3.Introducing smoke in 15 second intervals may allow smaller leak areas to be more noticeable. When the system is less pressurized, the smoke will sometimes escape in a more condensed manner.
5.This step verifies proper operation of the FTP sensor.
7.A normal operating FTP sensor should increase above 5 inches of H2O and stop between 6-7 inches of H2O.
Step
Action
Values
Yes
No
Schematic Reference: Evaporative Emissions Hose Routing Diagram
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
•Inspect the evaporative emission (EVAP) system for the following conditions:
• Loose, missing, or damaged service port schrader valve
• Loose, incorrect, missing, or damaged fuel fill cap
• A damaged EVAP canister purge solenoid valve
•Raise the vehicle on a hoist. Refer to Lifting and Jacking the Vehicle .
•Inspect the EVAP system for the following conditions:
• Disconnected, improperly routed, kinked, or damaged EVAP pipes and hoses
• A damaged EVAP canister vent solenoid valve or EVAP canister
Did you find and correct the condition?
Go to Step 21
Go to Step 3
Important: Larger volume fuel tanks and/or those with lower fuel levels may require several minutes for the floating indicator to stabilize.
•Turn OFF the ignition.
Important: Refer to the J 41413-200 Evaporative Emissions System Tester (EEST) operation for detailed instructions.
•Install the GE-41415-50 Fuel Tank Cap Adapter to the fuel fill pipe.
•Use the flow meter on the J 41413-200 to determine if there is a leak greater than 0.51 mm (0.02 in) in the EVAP system.
•Compare the flow meter stable floating indicator position to the red flag.
Is the floating indicator below the red flag?
Go to Step 6
Go to Step 4
Important: Ensure that the vehicle underbody temperature is similar to the ambient temperature and allow the surrounding air to stabilize before starting the diagnostic procedure. System flow will be less with higher temperatures.
•With the J 41413-200 connected to the vehicle filler neck, apply smoke to the EVAP system.
Did you locate and repair a leak source?
Go to Step 21
Go to Step 5
•Disconnect the GE-41415-50 from the fuel fill pipe.
•Install the fuel fill cap to the fuel fill pipe.
•Connect the J 41413-200 nitrogen/smoke supply hose to the EVAP service port.
•Use the remote switch to introduce smoke into the EVAP system.
•Inspect the entire EVAP system for exiting smoke with a the J 41413-SPT High Intensity White Light.
•Continue to introduce smoke at 15-second intervals until the leak source has been located.
Go to Step 21
Go to Step 6
•Use the remote switch to stop introducing smoke, if necessary.
•Install the GE-41415-50 to the fuel fill pipe.
•Connect the J 41413-200 nitrogen/smoke supply hose and vehicle fuel fill cap to the GE-41415-50 .
•Command the EVAP canister vent solenoid valve open with a scan tool.
•Compare the fuel tank pressure sensor parameter with a scan tool to the J 41413-200 pressure/vacuum gage.
Is the difference between the 2 gages less than the specified value?
1 in H2O
Go to Step 7
Go to Step 14
•Seal the EVAP system using the EVAP Purge/Seal function with a scan tool.
•Turn the nitrogen/smoke valve on the J 41413-200 control panel to NITROGEN.
•Use the J 41413-200 to pressurize the EVAP system to the first specified value.
Is the fuel tank pressure sensor parameter more than the second specified value?
10 in H2O
5 in H2O
Go to Step 8
Go to Step 14
•Use the remote switch to stop introducing nitrogen into the EVAP system.
•Increase the EVAP canister purge solenoid valve to 100 percent.
Is the fuel tank pressure sensor parameter less than the specified value?
1 in H2O
Go to Step 9
Go to Step 11
•Connect the nitrogen/smoke hose to the EVAP service port.
•Remove the GE-41415-50 .
•Start the engine.
•Allow the engine to idle.
•Use the purge/seal function to seal the system, with a scan tool.
•Command the EVAP canister purge solenoid valve to 30 percent.
•Observe the vacuum/pressure gage on the J 41413-200 and the FTP parameter on the scan tool.
•Allow the vacuum to increase on the gage of the J 41413-200 , until it reaches approximately 16 inches H2O or until the vacuum reached the abort limit on a scan tool.
Was the difference between the 2 gages less than the specified value?
1 in H2O
Go to Step 10
Go to Step 14
Did the FTP parameter on a scan tool display more than the specified value?
3.2 V
Go to Diagnostic Aids
Go to Step 17
Disconnect the EVAP canister purge pipe from the EVAP purge solenoid valve.
1 in H2O
Go to Step 18
Go to Step 12
12
Disconnect the EVAP purge pipe at the EVAP canister.
1 in H2O
Go to Step 19
Go to Step 13
13
Disconnect the EVAP vapor pipe at the EVAP canister.
1 in H2O
Go to Step 20
Go to Step 16
14
Test for an intermittent and for a poor connection at the fuel tank pressure (FTP) sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 21
Go to Step 15
Test the low reference circuit of the FTP sensor for an open or for high resistance.
Go to Step 21
Go to Step 17
Repair the pinched or obstructed EVAP vapor pipe.
Did you complete the repair?
Go to Step 21
17
Replace the FTP sensor. Refer to Fuel Tank Pressure Sensor Replacement .
Did you complete the replacement?
Go to Step 21
18
Replace the EVAP canister purge solenoid valve. Refer to Evaporative Emission Canister Purge Solenoid Valve Replacement .
Go to Step 21
19
Repair the restriction in the EVAP purge pipe.
Go to Step 21
20
Replace the EVAP canister. Refer to Evaporative Emission Canister Replacement .
Go to Step 21
Important: Refer to the J 41413-200 operation manual for detailed instructions.
Go to Step 22
Go to Step 4
22
•Observe the J 41413-200 pressure/vacuum gage.
•Increase the EVAP purge solenoid valve to 100 percent.
Does the pressure decrease?
Go to Step 23
Go to Step 2
23
Compare the FTP sensor parameter with a scan tool to the J 41413-200 pressure/vacuum gage.
1 in H2O
Go to Step 24
Go to Step 2
24
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List - Vehicle
System OK
© 2009 General Motors Corporation. All rights reserved.
Service Information
DTC P0455
System Description
ON
Open
Closed
OFF
Closed
Open
DTC Descriptor
Diagnostic Aids
Test Description
Step
Action
Values
Yes
No
Go to Step 2
Go to Step 21
Go to Step 3
Go to Step 6
Go to Step 4
Go to Step 21
Go to Step 5
Go to Step 21
Go to Step 6
1 in H2O
Go to Step 7
Go to Step 14
10 in H2O
5 in H2O
Go to Step 8
Go to Step 14
1 in H2O
Go to Step 9
Go to Step 11
•Start the engine.
1 in H2O
Go to Step 10
Go to Step 14
3.2 V
Go to Step 17
1 in H2O
Go to Step 18
Go to Step 12
12
1 in H2O
Go to Step 19
Go to Step 13
13
1 in H2O
Go to Step 20
Go to Step 16
14
Go to Step 21
Go to Step 15
Go to Step 21
Go to Step 17
Go to Step 21
17
Go to Step 21
18
Go to Step 21
19
Go to Step 21
20
Go to Step 21
Go to Step 22
Go to Step 4
22
Go to Step 23
Go to Step 2
23
1 in H2O
Go to Step 24
Go to Step 2
24
System OK
