For those with sporadic idle (2.0 specific) - DO NOT IGNORE IT
Originally Posted by Bishop
How much for the reflash?????
Originally Posted by alleycat58
Mine happened at both times, when the RPMs dropped and at idle both. The car's been acting weird the past few days anyway, one time I shut the car off and pulled the key out and the motor was still running (WTF?) and the next day when I started the car it didn't want to start at first, then after it did all this blue smoke came out the exhaust like it was burning oil. So I don't know.
I want it fixed in a hurry too! They stuck me in an '06 Malibu LT - that thing SUCKS...
I'll keep a look-out for problems though, since both our cars were built in the same month
Originally Posted by phxSS
Funny you mention the car doesn't shut off when you pull the key out...when i start my car sometimes, and when I let go of the key, the starter keeps cranking the engine! it's only happened a few times though.
Just keep an eye on it, if the idle gets worse or it starts stalling when it shouldn't be (i.e. you're in neutral or the clutch is in), have em check it out, that's what teh warranty is there for.
Its supposed to do that ...tap the starter and the car keeps cranking until it starts. My redline and a few others do that...So im 99% sure its supposed to be that way.
She's HOOOOOOOOOOME! So the service guy told me BCM...get there, look over the paperwork and they replaced the fuel pump. So I asked him about it, and he looked it over and he's like "Oh. Yeah, I guess they did." So basically my very first guess was right.
well uh, i just took mine in for the same thing...
mine has been doing this irractic idle off and on, then yesterday on the way home it cut off on the highway while in stop and go traffic...scared me to death to say the least, cause mainly, it wouldnt crank back up.
also my car is in for a horrible noise when turning left under load. just nasty sounding...no ripped boots though...should be interesting to see what they fine...
i get home and my dad and i crawl into the good 'ol sevice.gm.com website from home and start looking around. low and behold there is a document open on the irractic idle issue with the engine warm. document id # 1774823 to be exact. my cobalt is a 06 so that as you may. anyways, they recommend that you update the pcm, and if that doesnt fix it then leave it alone because they havent come out with a total fix for it yet. so ill have to live with it? i think not. this thing will be turned in under lemon law if they cant get a fix for it. after yesterday i could really care less about this car. GM knows there is an issue cause the document was just posted on 03/03/2006. so they know about it and they better fix it.
GM Vehicle Calibration Information
VIN: 1G8AY12P35Z118229...why does everyone one always hide this???
Controller: PCM/VCM Powertrain/Vehicle Control Module
Calibration History for: Control module
Part Number Cal.ID# CVN Bulletin # Description
12601903 12601904 0000DD96 - Revised Calibration
12589095 00009BC2
12596928 0000E0EB
12601905 00001FD6
12601906 0000A82C
12589092 0000E1AF
12589093 00006666
12589089 0000FCAA
12598558 12598559 0000261B - Revised Calibration
12589095 00009BC2
12596928 0000E0EB
12598560 000094B7
12598561 000011A3
12589092 0000E1AF
12589093 00006666
12589089 0000FCAA
12596924 12596925 N/A - BC/ID: YKXC
12589095 00009BC2
12596928 0000E0EB
12596926 N/A
12596927 N/A
12589092 0000E1AF
12589093 00006666
12589089 0000FCAA
Print Close
#36
well the calibration they gave me seems to have fixed it sorta...its only done it once since i had it updated, but now the car feels alot different and it feels like the bypass valve is being more abrupt when ive got a light load on the car and speeding up...this is starting to get to me, :-(
they had to order a left front axle assy. for that noise to. according to the tech that they called about the question of the noise, they've been having this problem with alot of them????
#37
i have an 06 SS/SC and i am having the same problem. dosent matter if the engine is cold or hot. it just randomly starts having a rough idle, usually when i am in neutral sitting at a light. after reading these posts, i think i will take my car to the dealer and see what they say. i will keep yall updated as to what happens.
#39
Iv had the problem 2 time sins I got the car. Both of them happend befor 800 miles on the car.
After I had a problem with the plug on the T/B and it was fixed I have not had any problems sins.
Ill let you know if I do.
Some one posted a link to file a comlaint in some of the thread dealing with the clutch problem.
It might help if we all started reporting the problem like they are with the clutch.
Later
Later
#40
Not sure if this classifys as the same problem but my car gets this rough take off, if I am on a roll or a dig the car waits 2 seconds before accepting throttle commands. You can hear an attempt of it trying to go and it hicups and then moves. It's very annoying and happens more times then not. I am 99% it's not the intakes fault either.
#44
Originally Posted by SuperCobaltSS
For Speratic Idle how bad is it i mean i can sit at a idle and itll just do it a TINY BIT i mean like hardly at all.
#45
WOW mine will only do that if i rev it at a stop light or somthing but it just goes up like 500 rpm then drops back down. GEEZ But doesnt it do that because of Vacuum or somthing?
#46
#47
So to get the reflash all i have to do is go to the dealer and ask them to reflash the car or what? Im not trying to sound like a N00B but what people have been saying is that the dealer dont know what there talking about.
Thanks
Thanks
#49
i got the same problem but mine dosent stall out in the moring it idles rough on start them smooths out but ever sents this started happening the car gose re re re re during idleing in gear or out gear is this what was happening to you
#50
While I don't have the exact same issue (nor the 2.0) on very rare occasions my RPMs have remained high when coming to a stop and hte car is in neutral. As an example I was doing about 50km/h in 2nd gear after having come off a turn and the road is too short to bother shifting to 3rd before I make my left-hand turn. As I come coasting up the light turns red so I ease my foot off the gas, allow the engine to slow me down and put it in neutral at about 2000RPM. I just happened to look down at the tach while sitting at the light and my revs were up in the ballpark of 2500 and I gurantee you my foot was NOT on the gas. I bliped the gas and all of a sudden it returned to normal and I didn't see it again the whole way home. It happens rarely but it still makes no sense to me why it's doing it...I've checked the gas pedal and it doesn't appear to be sticking at all and the only time it seems to happen is when coming to a stop.
