Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   Timing Chain Guide Fix (https://www.cobaltss.net/forums/problems-service-maintenance-69/timing-chain-guide-fix-307558/)
Chantie88 Mar 3, 2014 11:24 AM
Hey All,
I just wanted to let the Cobalt community know about a little miracle that I found!
Last summer I did a build on my engine, in process I found out that the top bolt holding my timing chain guide had actually SNAPED! The hole that held onto the bolt had actually ovaled and the guide its self was broken inside. I started to think the worst and thought I had to change my entire engine block to get it fixed. I did a lot of research on it and found the only guy who makes a fix. Its apparently a common problem with the ecotec’s, I didn't even know it was broken until I pulled my engine apart. I ordered the bolt and it was extremely easy to install and works fantastic! I honestly recommend you guys to just pick up this piece as a preventative measure even if you don’t have the problem right now. Picking up this part to prevent your timing chain from snapping and the possibility of having to change our engine for a few grand is worth it in my option.
Here’s a video about the part, a little corny but gets the job done :)
You can also contact Mike Brandt at mbrandt1952@yahoo.com if you would like to pick up the part, tell him Chantal from Toronto told you to contact him.
Staged07SS Mar 3, 2014 02:37 PM
subd
574 Mar 3, 2014 02:43 PM
ARP bolts FTW
Staged07SS Mar 3, 2014 02:49 PM
Originally Posted by 574 (Post 7289414)
ARP bolts FTW
Yup. I run those!
Twoozofjuice Mar 3, 2014 02:57 PM
in
Krizcobalt Mar 3, 2014 04:55 PM
Where can I get that bolt
Bass_Waves Mar 3, 2014 05:09 PM
Originally Posted by krizcobalt (Post 7289559)
where can i get that bolt
x2
sl0wlsj Mar 3, 2014 05:40 PM
The guy has them on eBay.
sl0wlsj Mar 3, 2014 05:41 PM
http://www.ebay.com/itm/Ecotec-2-0L-...-/301110934934
taintedred07 Mar 3, 2014 05:42 PM
Ced sells them $50
jlong3382 Mar 4, 2014 09:29 AM
I had my timing failure last year. Had to get the whole top end replaced. $50 is alot cheaper than the $2500 I paid to fix mine.
ItalianJoe1 Mar 4, 2014 12:08 PM
I heli-coiled the hole in the head while it was off and put another stock bolt from a used engine I had around back in. It held up but back then we didn't have the ARP bolts available.
Chantie88 Mar 5, 2014 11:32 AM
you guys can email the guy here to pick up the bolt.
Chantie88 Mar 5, 2014 11:44 AM
Also the ARP bolts are good if the bolt has not already snapped. Mine was snapped inside of the head, I had no idea until I put my Cams in. There was only one sign I had when the bolt was snapped. I always heard a slight ticking noise coming from my engine. I didn't know what it was, GM (not that they are any help) didn't know what it was and a few shoppes didn't know what it was. When I removed my valve cover I noticed a slight rubbing on the inside where the chain is, I investigated more and realized the bolt was snapped and the guide inside slightly broken. I was one of the lucky ones and I had no engine issues and my vales where ok (thank god) but most people don't get so lucky when it happens. The chain would usually snap and as one guy mentioned it could could a few thousand dollars worth of damage.
This bolt is a fix for when this happens or you can also us it to prevent the bolt from snapping. Its also recommended to get a tensioner as well to help tighten up the chain. If your bolt snaps there will most likely be some damage to the guides so pick up a timing chain kit as well.
chris88z24 Sep 26, 2014 08:51 PM
So what do you do, just remove the stock bolt and put the new one in?
T-fog Oct 4, 2014 05:17 PM
This ^^
Also where is the exact location of this bolt ? A picture would do best if someone could.
chris88z24 Oct 4, 2014 05:41 PM
I'm not touching mine until it makes noise. Sticking with the if it ain't broke don't fix it technique.
Powell Race Parts Oct 4, 2014 06:57 PM
Mr belvedere pioneered an ARP bolt fix for this a couple years ago. Works well CED and ZZP use the ARP fix as do I.
lsjion Oct 4, 2014 07:12 PM
If the head is off, you can weld a nut to the remaining bit of the bolt. A mig welder does the trick. Obviously since it won't stick to the aluminum it's easily done. I've saved a few from the scrap pile
YelloEye Oct 4, 2014 08:12 PM
Are you referring to this thread?
https://www.cobaltss.net/forums/2-0l...pgrade-298146/
ItalianJoe1 Jun 29, 2015 07:53 PM
Any chance these are still available? I need one for a local guy
TStone Jun 30, 2015 04:50 PM
Fix it right or don't fix it all. This is a halfass way of bandaiding the problem.
ItalianJoe1 Jun 30, 2015 08:30 PM
He already swapped the engine because the timing chain failed on the old one. This is the engine he just installed from the junkyard, it's already got the bolt backed out. He wanted me to install a new timing kit for him but I heard the rattle and pulled the plug to find the bolt backed out. At this point it's just fix the car to get it drivable, not pull the head and helicoil it and all that good stuff.
omarsiphone Dec 30, 2015 06:23 PM
I Absolutely need one of these. Where can i get or make one?
YelloEye Dec 31, 2015 02:15 AM
Crate Engine Depot carries them.
Did you shear off your OEM guide bolt?
