Timing Failure at 65K.....
Old Sep 21, 2013 | 08:50 AM
jlong3382's Avatar
Unhappy Timing Failure at 65K.....
On Monday I was driving my 50 mile commute home from work. I was low on fuel at the time but, I knew I could make it home. About 5 miles from home the tachometer started hiccupping about 300 rpm. At the time I thought it was from being low on fuel. No unusual lights or anything (except for the low fuel light of course). I got home and shut the car off. Being afraid I was so low on gas the car would not restart, I went down to the barn to get the 5 gallon gas can and took another vehicle in to the nearest town (10 miles away) to get gas. When I returned, I put the 5 gallons in the car and ate dinner.
The next morning, I went to start the car and it cranked but didn’t even try to start. Over the next 2 days, in my spare time, I tested for fuel pressure and spark on all cylinders. It had both. On Thursday, out of ideas, I had it towed to the dealership.
On Friday, I got a call from the service advisor……….
There was no compression on ANY of the cylinders. They checked the timing and it was off. They called it “timing system component failure.” As most of you know the 2.2L (L61) is an interference engine. Meaning that if there is a “timing system component failure,” the valves decide that want to get intimate with the pistons.
Has anyone ever heard of this happening to a 2.2L with only 65K? I keep up on my maintenance religiously. Please share your thoughts.
UPDATE: The timing tensioner failed. The timing chain jumped and bent the valves. Lower end of engine is ok. Upper end of engine being rebuilt.
Old Sep 21, 2013 | 08:52 AM
Did the tensioner just crap out on you? Are you a stock L61? I drove the crap outta my old L61 and traded it in at 93k no issues at all
Old Sep 21, 2013 | 09:19 AM
Xmetalhead2003X's Avatar
I'm creeping on 62k and don't have any issues. Routine maintenance always done. If you're stock, I don't know what would cause it other than a chain or guide.
Old Sep 21, 2013 | 09:25 AM
Hopefully you still have powertrain warranty! Otherwise, i smell an engine build!
Old Sep 21, 2013 | 09:34 AM
mongorat427's Avatar
I bought a couple engines that the black guide failed up on top causing various problems including bent valves
Old Sep 21, 2013 | 10:28 AM
574's Avatar
574
Where you at in Indiana?? I'm in southbend. Does not sound good for sure
Old Sep 21, 2013 | 11:37 AM
jlong3382's Avatar
It's got an intake, full exhaust, and a tune. I don't know what exactly failed yet, they're still taking it apart.
Powertrain warranty ran out in January.
Old Sep 21, 2013 | 05:35 PM
nhanson's Avatar
This doesnt sound right. You should hear when valves hit pistons. Also if the car cranked just fine then it just seem right.
Pull the valve cover yourself and look.
Old Sep 21, 2013 | 10:03 PM
silvercharged's Avatar
Doesnt add up it ran when shut off... So when did it go boom then because you would hear it make unusual noises
Old Sep 23, 2013 | 09:32 PM
jlong3382's Avatar
That's what I thought. The engine did crank more quickly than normal. They're still taking things apart. I've been doing business with this dealership for years and they've never cheated me.
Old Sep 23, 2013 | 09:59 PM
armcclure's Avatar
Old Sep 24, 2013 | 08:42 AM
jlong3382's Avatar
I'm about 10 miles SW of Bluffton.
Old Sep 24, 2013 | 08:43 AM
armcclure's Avatar
Like poneto / liberty center area?
Old Sep 24, 2013 | 09:01 AM
jlong3382's Avatar
Further than that. I'm in the boot of Wells county.
Old Sep 24, 2013 | 11:10 AM
armcclure's Avatar
Ahh jackson township. Mcnatt/dillman? I grew up just east of SW. Graduated 07. Always hung out over in jackson though with coco.
Old Sep 24, 2013 | 03:52 PM
BLKLS's Avatar
Most times when a timming chain component fails it does it on start up. That's a very stressful time on the engine. Sounds like maybe a guide or the tensioner failed and may have jumped a tooth when it was running, or became loose enough to make the timing stumble, when he went to start it is when it probably jumped time and bent the valves.
I at 110K, I updated my timing chain tensioner around 60k. Let us know what failed. I'd like to know.
Old Sep 24, 2013 | 08:44 PM
jlong3382's Avatar
That's interesting to know. I'll keep you updated.
Old Sep 25, 2013 | 11:51 AM
jlong3382's Avatar
Updated.
Old Sep 25, 2013 | 12:10 PM
umrdyldo's Avatar
Updated.
Damn, well good luck. Build her strong
Old Sep 26, 2013 | 08:56 AM
jlong3382's Avatar
The dealership the car is at is rebuilding it but, they are using the redesigned timing tensioner.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
