Tire rub on fender
Old Aug 21, 2014 | 03:42 PM
ak907's Avatar
Tire rub on fender
Ok I looked and seen some similar post about this but no fixes. My right rear tire rubs the fender when I hit a dip in the road. Had 235s but it wore through so I got 225s still the same how can I fix this problem b/c the left side is fine never rubs but the right looks like it may stick out a little more. I have CM lower springs and rims are enkei EV 5. Please help. Thanks.
Old Aug 21, 2014 | 05:40 PM
Hockeyman's Avatar
The passenger side pokes out about 1/2 inch more. Thanks GM.
Solution - Roll the fenders.
Old Aug 21, 2014 | 05:56 PM
ItalianJoe1's Avatar
Get proper sized wheels or raise the car a little, don't blame GM.
Why couldn't we trim the hub/backing plate mating surface a little and pull that wheel in for you stance guys? Or space out the other side and change offset accordingly.
Old Aug 21, 2014 | 06:08 PM
Originally Posted by ItalianJoe1
Get proper sized wheels or raise the car a little, don't blame GM. Why couldn't we trim the hub/backing plate mating surface a little and pull that wheel in for you stance guys? Or space out the other side and change offset accordingly.
Why not? Theyre the ones who built it all sideways lmao. You would have to shave the hub quite a bit. Easiest is rolling fenders or trimming them.
Old Aug 22, 2014 | 11:02 AM
ak907's Avatar
Thanks guys
Weird that posted though b/c I did it from the app and it said it couldn't post it
Old Aug 22, 2014 | 11:06 AM
Originally Posted by ak907
Thanks guys Weird that posted though b/c I did it from the app and it said it couldn't post it
Every time i post it says it failed but it always posts lol
bigdeertz
Nov 17, 2016 09:41 AM
deviance
Nov 24, 2015 05:51 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
