Torque Steer, how to get rid of it?
Old Jun 7, 2011 | 08:36 PM
Dimitri Manesis's Avatar
At a stop and when I floor it the wheel turns to the left. I have almost hit people. I think this is called Torque Steer? I have an automatic trans, and a chip that opens the throttle body immediately.
What causes this and how can I get rid of it?
Thanks,
Dimitri
Old Jun 7, 2011 | 08:38 PM
thedude411's Avatar
hmm my car torque steers to the right... Maybe we should trade some parts to balance out
BlueStang's Avatar
Don't stomp on it at a start, or buy a real vehicle with rear wheel drive
Old Jun 7, 2011 | 08:41 PM
Supabalt's Avatar
Only way i can figure out how to get rid of it is buy somethin other than a balt or a prius. i get tourque steer in 2nd gear at about 6800rpms lol
Old Jun 7, 2011 | 08:42 PM
black67's Avatar
Yes, that is torque steer. To get rid of it, don't take off so hard from lights.
Does the car have G85 in it? How are the tires wearing in the front? How is the air pressure of the tires? How well do you grip the wheel and where?
These are all things that you can look at to help against torque steer. But, if you are putting down major power, you will be fighting it hard.
Old Jun 7, 2011 | 08:44 PM
reefone's Avatar
hold on to the steering wheel better when launching.
Old Jun 7, 2011 | 08:49 PM
BLue NoTe's Avatar
Ive never found it to be an issue, and my right front is faaackin bald. The balts can handle themselves well, MS3s on the other hand...
Old Jun 7, 2011 | 08:50 PM
The engine is stock except for the K & N air intake and a muffler and a Trifecta engine and trans tune, no turbo. 10,000 miles on car. Tires 32 psi cold.
Dimitri
Old Jun 7, 2011 | 09:07 PM
AndrewSS/TC's Avatar
Grip the wheel tighter & and hold it straight. /thread.
Old Jun 7, 2011 | 09:19 PM
There has to be a solution? What about different motor mounts?
Old Jun 7, 2011 | 10:08 PM
elecblue06's Avatar
the only solution is learning to compensate with your arms. lift some weights
Old Jun 7, 2011 | 10:14 PM
let the car guide itself
Old Jun 7, 2011 | 10:24 PM
BLue NoTe's Avatar
Be the first to do a HIPER strut swap. Get yourself a Buick Regal and rip out its front end, then bolt it onto your balt
Old Jun 7, 2011 | 10:28 PM
You could just buy a Honda, no torque no torque steer....
Old Jun 7, 2011 | 10:29 PM
SlowCobaltSS's Avatar
Just turn the steering wheel to the right before u leave the light and it should straightened itself out
Old Jun 7, 2011 | 11:17 PM
insylem's Avatar
Old Jun 7, 2011 | 11:28 PM
05Slowline's Avatar
it's either a 2.2 or 2.4 so it's not torque steering anything noticeable unless your alignment is fucked up sorry
Old Jun 7, 2011 | 11:33 PM
RAIDERNATION 433's Avatar
^^^^this^^^^^^
Old Jun 7, 2011 | 11:50 PM
sLAsh's Avatar
Drive backwards instead
Old Jun 7, 2011 | 11:53 PM
Mindrot's Avatar
Learn how to properly launch a FWD car.
Old Jun 8, 2011 | 12:15 AM
BLAZIN07SS's Avatar
I'm too JDM for you
my car likes to try and change lanes from a roll
Old Jun 8, 2011 | 12:41 AM
Pedobear's Avatar
put some damn bricks in the engine bay weight that **** down son, or drive with a whale
Old Jun 8, 2011 | 10:37 AM
Phil424's Avatar
If you can't control torque steer, or figure out what it is....wow......
Old Jun 8, 2011 | 10:43 AM
sundevil07's Avatar
Ive let a couple of buddies drive my car and the oh **** look on there faces when the wheel tries to snap out of their hands is priceless
Old Jun 8, 2011 | 09:39 PM
rukkee's Avatar
Hmm...... I dont have huge issues with torque steer except on very uneven surfaces . Most car company's try to make equal length axles to combat the problem but the cobalt already has those so check the alignment and see where its at.
