Trunk ajar? Alarm going off
Old Jul 18, 2011 | 02:24 PM
ssblacksc's Avatar
My car has been saying that the trunk is open every time that I get in the car for a week. The trunk is closed but stills says it's open. Also for no reason the alarm will start going off. Does anyone know what to do to fix this?
Thanks
Old Jul 18, 2011 | 02:41 PM
insylem's Avatar
Could be people or animals bumping into your car. Squirrels or cats ontop of it setting off the alarm?
Are you accidently hitting the buttons on your key FOB?
Old Jul 18, 2011 | 04:21 PM
mrbelvedere's Avatar
check the close switch on the latch system
Old Jul 18, 2011 | 05:04 PM
ssblacksc's Avatar
the keys are sitting on the counter so not hitting the fob. How do I check the latch and what do I look for? I know where it latches at but is there a wire or fuse that may be loose?
Old Jul 18, 2011 | 06:45 PM
TommyP's Avatar
AWD > FWD
Tom, there are 2 bolts holding the latch in. Take those out and you should be able to take the latch out. At least that's what I'm assuming since I've never done it, but that's what it looks like. There's a wire running to the latch, so I'd assume that goes to the sensor on the latch. That sensor could have gone bad. Idk how to test that, but that's at least something to look at.
Old Aug 14, 2011 | 02:09 AM
ssblacksc's Avatar
I just saw this thanks Tommy I will try
Old Aug 14, 2011 | 01:55 PM
majourpain's Avatar
sounds like a hood or trunk switch. i had issues with my car setting off the car alarm all the time. turns out the hood switch went bad which is tied into the car alarm. yours sounds like the trunk swtch if you keep getting trunk ajar.
camaromanss1992
Oct 1, 2015 10:51 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
brickloaf
Sep 6, 2015 05:55 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
