Trunk release
Old Jan 13, 2014 | 02:02 PM
Boz1285's Avatar
Trunk release
Need some help. My trunk release won't work on my key fob or the button in the dash. When I hit the release the lights flash and I here a click under the hood. I checked the fuse and it's still good.
Any ideas?
Old Jan 20, 2014 | 11:58 PM
megaman311's Avatar
check the actuator that is in the trunk on the latch itself. the actuator could have gone bad. and also check the connector and you can even put a test light into the wire that is supposed to activate the actuator. if it lights up during the button press, you can assume the actuator is bad
Old Jan 21, 2014 | 12:15 AM
Shanedude's Avatar
Curl up in your trunk and try to watch the action. Or lack of action.
Old Jan 30, 2014 | 09:37 AM
Boz1285's Avatar
right on, thanks guys. i'll check it out
Old Jan 30, 2014 | 10:25 AM
northvibe's Avatar
make sure you have the seats down, or know where the trunk release is first but ya good idea.
Old Jan 30, 2014 | 08:27 PM
YelloEye's Avatar
Alternatively, you can close the latch with a screwdriver and then hit the button with the trunk still open.
Old Feb 16, 2014 | 05:58 PM
treytaw's Avatar
Hello all, was going to make a new thread but figured I would post in this one.
My interior trunk release button stopped working for some reason and I'm thinking its the button itself because the trunk releases with the key fob just fine. Anyone else had this problem and knows a solution.
Old Feb 17, 2014 | 11:35 AM
northvibe's Avatar
Check the button to see if it is wired, or became detached.
Old Feb 17, 2014 | 03:05 PM
BlackielawlessSS's Avatar
Check the fuse first.
Old Feb 20, 2014 | 08:36 PM
treytaw's Avatar
Not the fuse. Already checked that as the first thing so guess ill just have to check out the button.
Thanks,
Trey
camaromanss1992
Oct 1, 2015 10:51 PM
royce777
Sep 28, 2015 07:11 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
