Turbo to manifold causing car to lose boost?
So my 09 lnf has a turbo to manifold leak not sure if it's a stud letting go or the turbo gasket. Anyways, the car right now is running quite lean at wot around 13.8 (usually im around the low 12's) my knowledge of turbo cars is not very good as I've just recently bought car and I'm just curious to as if its that leak that's making me run lean. Im assuming so as I'm throwing a lean at idle bank 1 code Also, I seem to be losing boost at wot in 3rd but in 4th the car seems to hold its boost and pull harder. and I just dont think it's from the leak on the turbo but I could be wrong which is why I'm here lol. I'm currently not at home to check my charge pipes as they could very well be the cause of lost boost but I'm just wondering if it could be anything else I'm not aware of. Thanks in advance. Apologies if I'm sounding dumb here 😂
Originally Posted by Baltz
(Post 7735850)
(Post 7735851)
Very possible that a leak is causing your lean condition. Read the code. Also check charge pipes and around the intercooler. The stock intercooler is known to crack since the end tanks are plastic.
(Post 7735850)
| All times are GMT -4. The time now is 01:18 AM. |
