Turbo to manifold causing car to lose boost?
Old Aug 16, 2020 | 08:00 PM
Baltz's Avatar
So my 09 lnf has a turbo to manifold leak not sure if it's a stud letting go or the turbo gasket. Anyways, the car right now is running quite lean at wot around 13.8 (usually im around the low 12's) my knowledge of turbo cars is not very good as I've just recently bought car and I'm just curious to as if its that leak that's making me run lean. Im assuming so as I'm throwing a lean at idle bank 1 code Also, I seem to be losing boost at wot in 3rd but in 4th the car seems to hold its boost and pull harder. and I just dont think it's from the leak on the turbo but I could be wrong which is why I'm here lol. I'm currently not at home to check my charge pipes as they could very well be the cause of lost boost but I'm just wondering if it could be anything else I'm not aware of. Thanks in advance. Apologies if I'm sounding dumb here 😂
Old Aug 16, 2020 | 08:19 PM
blu3_v1p3r's Avatar
Very possible that a leak is causing your lean condition. Read the code. Also check charge pipes and around the intercooler. The stock intercooler is known to crack since the end tanks are plastic.
Old Aug 16, 2020 | 08:21 PM
Baltz's Avatar
thanks will do! Car has a zzp intercooler on it but I'll still give it a check.
Old Aug 17, 2020 | 04:07 PM
steelmesh's Avatar
If the exhaust leak is before the WBO2 sensor that could cause false readings, depending on the engine conditions and the leak. Look for any cracks in your manifold too (mirror and flashlight). An easy way to spot a manifold leak is to look for a tell-tale black streak of carbon near the manifold flange on the head, that is where exhaust is spewing out.
soundjunky
May 27, 2019 05:30 PM
CobaltSSTC
Nov 12, 2015 12:00 PM
Maccoy316
Nov 1, 2012 05:25 PM
Sully20
May 25, 2012 02:45 PM
