Turbo Timer Wiring Help
Ok So I Wanna Get My Turbo Timer Worked Out So When I Go Turbo Im Ready So Has Anyone With A Cobalt Hooked Up A Turbo Timer ? Also What Wires Would I Have To Connect
- Red -12v
- Blue- Acc
- Black- Ground
well i just installed mine...ill put some pics up here in a bit
its real easy....just cut the red/white wire thats ur 12v constant...that will go to your turbo timer red wire....just plice them both together.
Then the brown wire is your ACC cut it and splice it to your blue wire on the timer
black is your ground so ground it somewhere
and green is pretty easy....theres a pink wire real close to the bottom...i have in the pics...so you can see it better...that is your on which goes to green on ur timer....real easy but yea i got lots of pics
working on it right now...pictures are uploading
http://s269.photobucket.com/albums/j...Picture045.flv
in this pic where you see the 2 blues coming into the green on the turbo timer....that is actually a pink wire coming out of a connector from that black box in the background....that blue wire that i cut is the ON for my amplifier....which i got the power from the pink wire from that connector
oh by the way dont forget to check out my huarache on the lower left corner....lol
turbo on the TC is water and old cooled. Unless you're drag racing right into your drive way normal driving will have it plenty cooled to just shut it off when you get where you're going. You've got TC upper grilles so I'm assuming TC, in which case you really don't need a TT.
Ive never ran a turbo timer. If i beat the everliving **** out of it il let it idle for a 30 seconds then turn it off. never had a issue in 3 years running a ebay turbo... just saying man...
