Uhh, wtf?
Old Nov 2, 2010 | 10:06 PM
damien's Avatar
Uhh, wtf?
So I was filling up tonight and when I was done as I went to pull away a loud hissing sound and visible smoke/steam was coming from my engine bay/underneath. I shut the car off and looked under saw nothing out of the ordinary. I pushed the car to a spot to check it out and under the A/C pressure sensor/hose/compressor I could see visible green fluid on the subframe and sensor itself. I couldn't really smell anything abnormal either.
Is this freon? IIRC freon is supposed to be colorless..
Any ideas?
Old Nov 2, 2010 | 10:08 PM
Dart_SI's Avatar
suprize NOS purge!!!
really tho, i belive you have a coolant leak.
Old Nov 2, 2010 | 10:12 PM
ls1fbody's Avatar
Haz l33t wheelz.
it's definitely not freon.
It's probably 134r or whatever, and i do think it's green.
Our coolant is a pinkish orange...
Old Nov 2, 2010 | 10:13 PM
damien's Avatar
No I have pink coolant
It would be whatever factory fluid is. Well maybe, a body shop might have refilled it a while back.
Old Nov 2, 2010 | 10:17 PM
Dart_SI's Avatar
hm, didnt know that. all i know is the coolant in my other cars was green. well hope its not a major problem.
Old Nov 2, 2010 | 10:31 PM
dspeed123's Avatar
It's the A/C system. The fluid has a neon green/yellow color to it. Not really a big deal if you don't plan on using it anytime soon. I personally left mine with no charge for like 8 months.
Old Nov 2, 2010 | 11:05 PM
damien's Avatar
Yea, I knew it had to be something with the A/C. Just for testing I tried running the A/C. Sounded very funny and it did not get cold at all.
It's winter here now anyway, hopefully the car is gone by next summer...
Old Nov 3, 2010 | 01:27 PM
scottie's Avatar
R134 is freon.. And if it has leak detector in it, which is neon green, then it could very well be ac system leaking.
Old Nov 3, 2010 | 01:33 PM
thesteed46's Avatar
It's the oil they put in the compressor. Freon is colorless, you are correct.
It sounds like you have a leak.
Old Nov 4, 2010 | 08:31 AM
trey ss's Avatar
freon is green and smells like complete ass, jus check you AC piping sometimes they can get holes rubed threw the soft aluminum
Old Nov 4, 2010 | 10:35 AM
thesteed46's Avatar
Freon is colorless and odorless.
Old Nov 4, 2010 | 12:37 PM
383_Stroker's Avatar
Freon is a brand of refrigerant... k thx...
Old Nov 4, 2010 | 01:23 PM
thesteed46's Avatar
Freon/R134, whatever you want to call it.
Old Nov 4, 2010 | 01:25 PM
redcobalt07's Avatar
and yes it is colorless but they do put the green yellow dye in it to detect leaks
Old Nov 4, 2010 | 01:49 PM
elecblue06's Avatar
it is not odorless lol we had a refrigerator tank get punctured in my office that **** smelled REALLY bad.. and my car that leaks R134 has the same smell when i turn the ac on
Old Nov 4, 2010 | 01:51 PM
thesteed46's Avatar
It's something else then. You sure you didn't fart?
Old Nov 4, 2010 | 01:57 PM
elecblue06's Avatar
it's not something else man.. poison control came to my office ..and said it was freon..
Old Nov 4, 2010 | 02:02 PM
thesteed46's Avatar
Well then my instructors lied to me.
Old Nov 4, 2010 | 02:12 PM
elecblue06's Avatar
it's not a huge odor but if you put enough of it in the area you'll smell it lol
Old Nov 4, 2010 | 02:17 PM
thesteed46's Avatar
Yeah idk, I did the process on multiple cars and never smelled anything. That was in a shop with Idk 30 bays, so maybe it was masked by other smells or something.
Old Nov 4, 2010 | 02:44 PM
elecblue06's Avatar
yea that probably helped being in alot of bays . but **** in our office started off as no smell
then got worse through the day.. with al lthe windows closed.. then someone opened the fridge and the smell just started pouring out lol and all there was in it was bottles of water lol
Old Nov 4, 2010 | 02:47 PM
BLAZIN07SS's Avatar
I'm too JDM for you
$10 you were trying to log your wideband through the ac pressure sensor
Old Nov 6, 2010 | 01:16 PM
damien's Avatar
Yup.
Old Nov 6, 2010 | 01:49 PM
Silv3r's Avatar
Just for the record your defrost still uses your A/C in the winter, I'd get it fixed.
Old Nov 6, 2010 | 02:04 PM
damien's Avatar
Everything is working fine, including Defrost. It doesn't interfere with my AC at all.
Cobalt08LS
Jun 19, 2016 07:29 PM
Getaway_Driver
13
Aug 30, 2015 02:44 PM
Blackey2005
Sep 11, 2011 01:06 AM
