Vacuum leak?
Vacuum leak?
I noticed as i was driving(mostly starting from stop) that when i take the clutch out, just after it catches there will be a pshhhh sound as if something is sucking in or blowing air, it only does it until the clutch is fully out, any ideas what that could be? Or is that normal?
I normally give you the benefit of doubt on your posts but this is going too far to a new member. Your post has been reported. You cannot act this way on this site. Please go away.
what you are describing is a clutch noise. i had that when i put my gmpp clutch in, it eventually went away. ive had it in various other vehicles ive put clutches into as well.
Long story short, i bought a new engine from a scrap yard and droped it in my car, so yes there is a new clutch, the clutch was not brand new but new ish to the engine , also the sound is as if there is air blowing out a hose, thats what it sounds like im not really sure how to explain it
yea thats the noise of the disc slipping against the flywheel and pressure plate. if the flywheel was machined and it was left rough it could make it louder.
basicly its nothing to worry about.
