Valve stem snapped...
Old Mar 22, 2011 | 11:10 PM
JAYNO20's Avatar
What... The... ****... That's what I said while trying to get my valve stem caps off.. they were like corroded on. Anyway, after trying for a bit the whole thing snapped in half and now all the air is spilling out of my tire. What am I going to have to do to get this fixed? I assume I can't use a regular valve stem due to the TPS, right?
Old Mar 22, 2011 | 11:58 PM
Phil424's Avatar
Tire has to be taken to a tire shop etc to have a new valve stem put in. You can't replace it without taking the tire off the rim, which you can't do without a tire machine. They will prollcharge u around 15-20 bucks.
Old Mar 23, 2011 | 12:34 AM
JAYNO20's Avatar
Is that the case even with the TPS? Isn't it all one piece?
Old Mar 23, 2011 | 08:52 PM
Malaclypse's Avatar
You need a new tore monitor sensor. Same procedure with removing the tire and all that.. but with a much greater parts cost.
Hopefully you saved the nut part off the stem that broke.
Old Mar 23, 2011 | 10:09 PM
JAYNO20's Avatar
Yeah I did, why would that matter though?
Old Mar 23, 2011 | 10:10 PM
DavidW's Avatar
warranty...
Old Mar 23, 2011 | 10:27 PM
09sscalicobalt's Avatar
haha warranty wont cover that just take to a tire store when i got new rims i hada buy new tpms sensors but last time i went to get new tires i didnt have to so they might be able to save them just go down or call and ask
Old Mar 23, 2011 | 10:29 PM
BlackLsCoupe's Avatar
actualy it does in some cases. idk about his tho. discount tire has new ones cheaper too i think
Old Mar 23, 2011 | 10:32 PM
PRND3L's Avatar
if you had a non factory valve cap, its not warranty. Happens by us all the time.
Old Mar 23, 2011 | 10:36 PM
Malaclypse's Avatar
The new sensor doesn't come with the nut that holds it in. Don't ask me why...
Old Mar 24, 2011 | 01:29 AM
JAYNO20's Avatar
it's a factory cap... Why wouldn't they cover this under warranty?
Old Mar 24, 2011 | 07:38 AM
mongorat427's Avatar
I bought 4 new sensors on Ebay for 75 bucks. They were in GM packages. After the tire shop installed them I reprogramed them myself
Old Mar 24, 2011 | 09:34 AM
DavidW's Avatar
this can be warrantied, its just all about if your dealer will do it for you...
Old Mar 24, 2011 | 01:52 PM
PRND3L's Avatar
Using non factory caps can allow water into the stem and corode faster. You should have any issues getting it replaced. It happens at my dealer all the time.
Old Mar 24, 2011 | 03:57 PM
06SS ALL DAY's Avatar
if you get a pep boys discount or points card. i forgot what they call it but you get free tire plugs, balance, stems etc... u just have to let them do it and wait a hour lol. idk the places i drive i have a nail in a tire at least once every 6 months... i swear there is magnets on my wheels because i even avoide gravel n such. Philly FTL
Old Mar 27, 2011 | 05:29 PM
JAYNO20's Avatar
from what I'm seeing it looks like you can replace just the valve stem, not the whole sensor... Is that correct?
Old Mar 27, 2011 | 05:36 PM
outtamymind's Avatar
no the stem is part of the sensor and can not be replaced individually. if it were the rubber ones then yes they can be replaced individually and as others have said as long as its the stock valve stem cap it will be covered under warranty. i can't even count how many i've replaced under warranty.
Old Mar 27, 2011 | 05:38 PM
gotboost?17's Avatar
Nothin Stock
lol thats normal on gm stems
Old Mar 27, 2011 | 05:42 PM
JAYNO20's Avatar
Bought the car used so I can't be sure they are stock... Knowing my luck, I won't get these replaced under warranty...
Anyone have a close up picture of what the stock caps look like?
Old Mar 27, 2011 | 05:44 PM
they are small and gray with vertical slits
Old Mar 27, 2011 | 05:46 PM
JAYNO20's Avatar
Mine don't look like that... but they do look exactly like these ones here which are also GM factory...
GM Tire Pressure SENSOR Valve Stems! SET OF 4! Cheap! - eBay (item 190418220867 end time Apr-09-11 15:29:47 PDT)
Old Mar 27, 2011 | 05:48 PM
you have the rubber ones or the metal ones. the ones you posted are the stock rubber valve stems but they have the "chrome" covers on them which are not stock, also those valve stem caps aren't stock in the link either.
Old Mar 27, 2011 | 05:49 PM
JAYNO20's Avatar
Awesome.
Old Mar 27, 2011 | 05:52 PM
JAYNO20's Avatar
Looks like I am paying for this one....
Any ideas on how to get the other 3 caps off without breaking the other 3 sensors?
Old Mar 27, 2011 | 05:53 PM
do you have these ones
or these ones
