very loud CLICK/THUD!!!
Old Feb 23, 2009 | 04:08 AM
andrewscobaltss's Avatar
Unhappy very loud CLICK/THUD!!!
IDK what it is... its coming from passenger front. When i turn my wheel quickly from right to leck it clicks, and when i go over a bump it clicks, and when i either accelerate or slow down really quick it clicks!! Any ideas?? its not the axels or cv's because i just replaced them with stage 2's.....
its got the tenzo r lowering springs...(for the record)....
Sry about the bad gramer i am on my blackberry storm doing this)
Old Feb 23, 2009 | 04:15 AM
REIGN SS's Avatar
Original Hayden Fanatic
Storm has a full keyboard and spell check, I blame the operator not the phone
Did the noise start after you installed the stg2's or the springs?
Old Feb 23, 2009 | 04:29 AM
lol operater too lazy to check them lol
it started about one year after the springs. i put the stage twos in afer it started clicking because i thought it might be bad axels or cv's.....
Old May 9, 2009 | 11:36 PM
Old May 10, 2009 | 08:58 PM
Old May 10, 2009 | 09:06 PM
3fo893013L's Avatar
sound like this?
http://www.seecarclub.net/forum/index.php?topic=2550.0
member in our club had clicking and thought it was a cv joint.
Old May 10, 2009 | 09:09 PM
idk I am on my I touch. It won't let me view it. I will check my pc when I get home in the am.
GreyDog72's Avatar
how many miles do you have? could it be tie rod end or ball joints? get those try greasing your front end parts the require grease
Old May 10, 2009 | 09:11 PM
06BrandonSS's Avatar
Sounds similar to when I had my car...sway bar link. I went through 3 of them while I had the car. Made knocking noise as if the strut was bad.
Old May 10, 2009 | 10:01 PM
35000 miles on it. I was kinds thinking maybe swaybar links but wasn't sure. How hard is it to replace them?
Old May 10, 2009 | 10:06 PM
blacksssc05's Avatar
sounds like an axel...mine did the same thing and it was the axel
Old May 10, 2009 | 10:10 PM
Dealer did all mine because of warranty but its one bolt on the sway bar one on the control arm I believe, and they like to spin when unbolted so they're a pain in the ass to remove.
Old May 10, 2009 | 10:11 PM
silver06cobalt's Avatar
Sounds to me like the spring isnt seated correctly
Old May 10, 2009 | 10:12 PM
jlong3382's Avatar
I hope this helps.
When I put on my Eibach's it did the same thing. I checked it out and after MUCH searching i found that the stabilizer bar, when installed on the same side of the strut as it originally was (from the factory), rubbed against the CV shaft when I turned left. I unbolted the stabilizer bar and reattached it to the opposite side of the strut and the problem went away. Hope this helps.
Old May 10, 2009 | 10:17 PM
if the spring wasn't seated properly wouldn't it have started when I lowered it?
Old May 10, 2009 | 10:47 PM
ziggity's Avatar
I had the exact same problem just brang it in the other day they said the stabilizer arm was gone .. replaced it and no more noise
biniecki
Oct 25, 2015 02:23 PM
OrangeK
Sep 20, 2015 03:02 AM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
Infamous SC/SS
Sep 4, 2015 05:33 PM
Adam144
Sep 3, 2015 07:48 PM
