View Poll Results: Will the Dealer warranty my engine?
No, the headder voids your warranty
33.33%
Yes, the headder has nothing to do with the piston rings
36.11%
no idea.
30.56%
Voters: 36. You may not vote on this poll
Warranty?
Old Oct 12, 2007 | 06:29 PM
BallsoutBalt's Avatar
Warranty?
So here is the question at hand...
On my car I have A pace setter headder, Fujita CAI, and Hi-flow cat. I'm taking my car to the dealership tomorrow because my pistin rings are blown and my car throws out clouds of blue smoke. I know the rings are bad cuz the mechanic I took it to did a leak-down test and found #1 and #4 leak 90%.
Here is the questio...
Do you think the dealer will warraty the engine?
PLACE YOUR BETS!!!
Old Oct 12, 2007 | 06:30 PM
an0malous's Avatar
go back to stock IMO.
Old Oct 12, 2007 | 06:31 PM
SSalexSS's Avatar
dealers are gay but they cannot take your warrany away unless the promblem is caused by the aftermarket parts
but usually its safe to put sotck back on
CobaltDude06's Avatar
start returning car to stock if you think it might be void
Old Oct 12, 2007 | 06:32 PM
rallyracer's Avatar
x2...Put the stock parts back on ASAP
tlax23's Avatar
Yes.
Cant put the stock manifild back on. The current exhaust won't mesh with it.
Old Oct 12, 2007 | 06:33 PM
UmeNNis's Avatar
hmm... you may be sol then... but hopefully not, you won't know til you try! but good luck either way!
Thanks man! I'll find out tomorrow. It's worth a shot though.
Old Oct 12, 2007 | 06:36 PM
Black SS/SC 06's Avatar
It depends on the stealership!
Old Oct 12, 2007 | 06:41 PM
XM15's Avatar
If they don't warranty it, I would be curious to see their reasoning behind it. And it better be different than "Its modded, so its not under warranty."
Old Oct 12, 2007 | 06:43 PM
if they try to void it say screw u and go to a different stealership
Old Oct 12, 2007 | 06:44 PM
HAHA
Old Oct 12, 2007 | 08:28 PM
Indeed. I called the 800 # and they said that the dealership has to prove that the headder caused the rings to go bad. I have thought about it and I don't see annyway that could happen. Anyone else?
Friday night humpty BUMP!
Last edited by BallsoutBalt; Oct 12, 2007 at 08:28 PM. Reason: Automerged Doublepost
Old Oct 12, 2007 | 08:29 PM
Red2.4SS/SC's Avatar
its called a header one D
Old Oct 12, 2007 | 08:32 PM
cobalt.in.progress's Avatar
it's a stealership, theyre going to try to screw you over. If you can find a cheap oem exhaust put it on with your oem headers. IMO i'd try to avoid any chance of them voiding.
Old Oct 12, 2007 | 08:38 PM
Who called it "headers"?
Old Oct 12, 2007 | 08:48 PM
KillerBee's Avatar
in order for it to void your warrenty they need to put it in writing and explain why the header voids the warrenty and the reason why it caused the piston rings to go if thats the case
Old Oct 12, 2007 | 08:51 PM
69Chevy's Avatar
I've seen it spelt hedder too, as in Hedman Hedders.
But anywho- I don't see how a custom exhaust could cause the rings to go bad. Are you sure its the rings and not a valve issue, i.e. burnt or bent allowing oil to come past the seals? If it's smoking real bad though it probably is the rings.
Old Oct 13, 2007 | 12:59 AM
Mechanic did a Leak-down test, he said valves are fine, bings are bad.
Late night Bump?
Last edited by BallsoutBalt; Oct 13, 2007 at 12:59 AM. Reason: Automerged Doublepost
Old Oct 13, 2007 | 01:56 AM
Archie's Avatar
You can burn up your valves by having a header/headers without any exhaust piping after it, or even from running with a leak for a long time.
On the other hand, I'm not sure if that would do anything to your rings.
Are you 100% sure it isn't the valves?
Now you said you have a high flow cat, do you have a CEL? Are you tuned?
A high flow cat will have your 02 sensor sending wrong info to the PCM, changing fuel and timing which they could possibly blame for the problem. Well at least that's what GM teaches some of there techies.
I say, go as close to stock as you can.
Old Oct 14, 2007 | 05:16 PM
rukkee's Avatar
The way the stealerships are about these cars i would take the extra time and go back to as close to stock as possible . If you don't have the stuff to do it look in the classified's and buy it, it's going to be alot cheaper than having the motor work done yourself.
Old Oct 15, 2007 | 12:59 PM
Okay so I put everything back as stock as I could. Still has headder, CAI and High-flow cat. Should be good right???
Taking it to the dealership toomorrow morning.
Wow, has anyone looked at the poll results? I haven't ever seen one so close. LOL
Last edited by BallsoutBalt; Oct 15, 2007 at 12:59 PM. Reason: Automerged Doublepost
Old Oct 16, 2007 | 09:17 PM
Slowbalt SS05's Avatar
Try completely stock you don’t want them to give you any but it is a Chevy dealership they will turn you around to save them self’s some bucks.
Old Oct 17, 2007 | 01:45 PM
^ I put it as back to stock as I could.
