Weird Engine Noise
Old Feb 7, 2017 | 02:10 PM
budah93's Avatar
Weird Engine Noise
When I start my car some mornings it's will make a quick squeak then go away and as it sits there in idle and it will sometimes make the noise again. When it happens the second time some times it's very quick and others will last for 30 seconds or so. If I'm in the car when it happens I can push on the gas and it will go away. It's more common when it's cold if that helps any. I'm at a loss as to what it could be. Any suggestions? Thank you!
Old Feb 7, 2017 | 03:15 PM
jdbaugh1's Avatar
Hard to diagnose a quick squeak but it is most likely a belt driven component causing the squeaking noise.
