What the?
What the?
OK...so i was driving along..60mph. Well stop sign ahead. So i downshift. 4th....down to 45mph...going to third *griniiiiinnd* WTF!????!?. Ok lets try this again..clutch in, smooth sailing now.
Fast forward 15 minutes..coming up to another stop sign..down shift..4th...45mph.
downshift 3rd..clutch in, to 3rd. *grind*..after a little grind..it lets me in.
Soo what the **** is wrong with my 3rd gear that it wont let me in it ever. I mean i hardly use third gear unless im acelerating hard. In town, i go 1st to 2nd to 4th.
Anyone else have this problem...
By the way, its already at the dealer..im just trying to figure out what the hell is wrong with my car.
Oh and sweet loaner car...a fucken van..tshh.
Because if i would put it in 3rd...i would be in it for like maybe 5 mph...im usually at 20-25..when i shift outta 2nd.
So i have just gotten outta the habit of using third for the most part unless im in really low rpms in 4th, in town.
I have a LS...but probably doesn't make a difference.
I guess i learn from my mistakes..didn't think skipping 3rd would make that big of a deal..
Well damn..car is already at the dealer and there working on it...
well there gonna have to tear apart the tranny.. cause the grinding is as stated above a synchro issue.. cause well they use ring's and teeth to speed up the gear your going into and slow down the gear your coming from..
Third gear felt bad cause he felt like you didn't need him so he just figured, screw you your on your own...............
Let us know what the dealer sez when you get it back...........
^ thats what i was wondering..
But yeh..called the dealer and they ordered new synchros today and should be in monday.
Plus im getting a new tire because mine popped somehow...and there touching a bad paint spot on my car, from when i bought it.
So when i down shift i should (when im in 4th) i should use 3rd..then go to second..then use brakes because your not supposed to use 1st when downshifting.
Heh..and i just oredered my intake..heh..intake should be here when my car comes home
WHY are you going into 4th gear AT 20 MPH??? NOOOOOOOOO NOT EVEN AT 30 UGH cmon people! This is so bad on your transmission. And so is downshifting so much... cmon, don't we all know that brakes are MUCH MUCH cheaper to replace than transmissions and/or clutches?????
why are you in 4th at 20? you're shifting WAY too low. that's putting a lot of extra stress on your car. i bet tht has something to do with your problem. i'm usually not in 4th untill at a minumum 50-60
the whole reason why you have gears is so that you can keep the engine in it's efficiency range. what you're doing is intentionally putting it out. we have very long gears in our car. some car 4th at 30 would be fine. for us that's very low. what do you shift at like 700-900rpms?
i got an ls and once u hit 2k rpm a light comes on telling u to upshift, so no hes not out of the effiency range. and also, ur second gear last up to 70 mph or so, ours last till around 45-50
