What could this be?
Old Nov 11, 2006 | 05:42 PM
Beanyhead's Avatar
What could this be?
Occasionally when I'm going on the expressway, my '06 balt starts to violently shake. If I apply the breaks, the shaking is even worse. Usually it'll do this the entire drive home, even when I'm going slower, 30/35mph... But later that day if I go out again, or whatever, it won't do this. What do you think this could be?
Thanks in advance!
Old Nov 11, 2006 | 05:45 PM
afireinside7710's Avatar
rotors?
Old Nov 11, 2006 | 05:47 PM
Beanyhead's Avatar
See, that's what I thought too, but the dealer had just replaced them.
Old Nov 11, 2006 | 05:49 PM
CTORANGESC's Avatar
Rotors are most likely warped form getting to hot. Thos is from expressway driving because you are going 60-70mph or whatever and then you hit the brakes to get off the expressway the heat up really fast because of all that fristion.
Old Nov 11, 2006 | 05:50 PM
CTORANGESC's Avatar
What kind of cobalt do you have?
Old Nov 11, 2006 | 05:55 PM
Beanyhead's Avatar
06 Ls
Old Nov 11, 2006 | 05:58 PM
CTORANGESC's Avatar
How long ago did they replace them?
Old Nov 11, 2006 | 06:01 PM
Beanyhead's Avatar
Uhh probably like a month or so?
Old Nov 11, 2006 | 06:05 PM
CTORANGESC's Avatar
Well they can be warped again im afraid to say, but I dont know for sure, how much highway driving do you do?
Old Nov 11, 2006 | 06:07 PM
n8dogg's Avatar
if your cars shaking with out your foot on the brake pedal, id check for the steering dampener.
Old Nov 11, 2006 | 06:08 PM
Beanyhead's Avatar
Not all that much. I would say I've only put on 2,000 miles or so total from when they were last replaced. I don't violently brake all the time or anything...
Old Nov 11, 2006 | 06:09 PM
CTORANGESC's Avatar
The other possabilty is that your tires could be out of balance
Old Nov 11, 2006 | 06:11 PM
Beanyhead's Avatar
Yeah, but I'm confused to why it would only does it occasionally when I'm driving on the highway, instead of constantly?
Old Nov 11, 2006 | 06:17 PM
CTORANGESC's Avatar
Unbalanced wheels will not vibrate all the time, only at certian speeds, likelets say 65, you can go 62 and it wont, the minute you hit 65 it shakes like hell, then when you hit like 70 it goes away
Old Nov 11, 2006 | 06:28 PM
Beanyhead's Avatar
Yes, but see, like I said, even after I get off the expressway, it'll still shake really bad when I'm going like 30 - 35 mph.
Old Nov 11, 2006 | 06:32 PM
RaineMan's Avatar
have you checked to see if your lugs are all tightened properly?
Old Nov 11, 2006 | 07:52 PM
Beanyhead's Avatar
I haven't but I'll check that out.
Old Nov 12, 2006 | 12:19 AM
Dustin's Avatar
That's scary.
Old Nov 12, 2006 | 12:22 AM
joedashow's Avatar
Maybe a tire rod?
Old Nov 12, 2006 | 12:34 AM
NinjaHampster's Avatar
Originally Posted by Exigen
That's scary.
your tellin me, in my old car i left discount tire and was a block away from my house when my back wheel fell off. one moment im driving the next im starin at the sky funny story now
Old Nov 12, 2006 | 01:26 AM
biohazard's Avatar
Get low
did you put aftermarket rims on?
Old Nov 12, 2006 | 02:07 AM
bdwarr6's Avatar
whoops i posted on the wrong thread silly me
Old Nov 12, 2006 | 02:16 AM
Magic Ninja 16's Avatar
Yeah that is what it sounds like to me too.
Old Nov 12, 2006 | 09:39 PM
βКˉSuPerCharged's Avatar
Are there any lights on in the dash? Your ABS system could be screwed causing it to clamp/unclamp your brakes and it does it so fast it feels like a bad vibration. Either way I would take it to the dealer because you may have a serious safety issue with your car.
Old Nov 13, 2006 | 01:39 AM
Beanyhead's Avatar
I don't have ABS, and no lights show up on the dash...
