What do I do
Old Jan 11, 2009 | 09:45 AM
Element27LS4dr's Avatar
What do I do
Hey guys, so I installed power locks into my front doors about 6 months ago and everything was working fine. The other day i wanted to install them into the rear doors as well. That worked for like a day but then stopped working suddenly. I think I may have blown a fuse. How do I fix this??
Old Jan 11, 2009 | 09:48 AM
originaladrian's Avatar
lol u installed power windows urself but dont kno how to change a fuse???
Old Jan 11, 2009 | 09:51 AM
Well it was power locks... and yeah i dont know how to change it
Old Jan 11, 2009 | 09:53 AM
mcphatty's Avatar
step 1) pull blown fuse
step 2) replace with new fuse of same amperage
done.
Old Jan 11, 2009 | 09:54 AM
Coblasts's Avatar
What circut where you powering the back door lock from .
or what color wire and where was it located.
Is this a aftermarket system that you are adding on ,or a retrofit of a stock door lock system.
If its aftermarket there must be a inline fuse or one in the reciver module that came with it other wise I would have to know where and what color wire to tell you what fuse it is that has blown.
Power winodow fuse is #29pwr wndw (30 amp) and doorlock fuse is#26 Drlck (15amp) if you used any of these circuts.
They are located in the bcm(fuse panel) on the passanger side check your manual for the exact location.
