what the hell is this horrible noise?
Old Dec 25, 2024 | 03:31 AM
xtcydom's Avatar
noticed the car has made this bone chilling screeching noise since I bought it, only happens when first turning the key over into acc mode before even starting the engine, sounds like some sort of electric motor going bad but im happy to replace it as soon as possible
Old Dec 26, 2024 | 06:18 AM
stevieturbo's Avatar
you need to have someone else cycle the key while you're looking and listening.
Old Apr 9, 2025 | 06:48 PM
2006lsjcobalt's Avatar
did you ever find out what it was? Mines making this now just not as loud
Old Mar 27, 2026 | 10:02 AM
branden.garrod.19786's Avatar
Recirculation door actuator motor
This clicking noise is an actuator motor for a blend door on the HVAC system. If it is in the upper passenger side of the dash it is the recirculation door if it is down in the middle of the dash by the throttle pedal then it is either the blend door (temperature) or the Mode door. There are three actuators, blend, mode, and recirculation. The clicking is the gears trying to open the door and slipping.. this is obvious bevause it happens when you turn the key to the on position and it tries to reset.
zmoney19
Aug 26, 2015 07:28 PM
awilson
Oct 13, 2013 12:23 PM
Axelthered05
Jun 9, 2012 04:44 PM
Jared B
Oct 9, 2007 03:27 PM
Incognito
Nov 1, 2006 02:48 PM
