Noise
Old Oct 8, 2007 | 09:03 PM
Jared B's Avatar
Noise
just started to here a new noise when i let of me clutchslow in 1st, when i shut my car off, and sometimes when its runing u can hear it then i goes away. it sounds like a whistel. anyone know wat it could be cant figure it out.
Old Oct 8, 2007 | 09:06 PM
ItalianJoe1's Avatar
what does it do when you shut it off?
Old Oct 8, 2007 | 09:07 PM
Jared B's Avatar
it does the same noise as soon as i turn the key and the motor goes to shut of it does it real quick
Old Oct 8, 2007 | 09:11 PM
Check your alternator, mine does something similar, you hear it winding down while the motor is stopping. I think it is the one-way clutch in the alternator sticking or going bad. Take the belt off and spin it back and forth by hand, you should hear the same noise. If not, its not what I have.
Old Oct 8, 2007 | 09:15 PM
Jared B's Avatar
they shouldnt go bad the car only has 6000k on it.
Old Oct 8, 2007 | 09:32 PM
Ok, sure. Just check it and see, it can't hurt.
Old Oct 9, 2007 | 03:27 PM
davyboy's Avatar
sounds like your air conditioning pump ...or your air conditioning ciutch ,they do make this kind of sound when they kick in or when you shut car off....this is normal
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
