What should I do now?
Old Apr 17, 2009 | 10:08 AM
Tank07's Avatar
my front rotors are warped to ****........warranty coverage is not gonna happen.....the dealer claims its a service claim since the car is a year and a half old.......i have just under 19K on it
the guy said the drums are most likely out off adjustment which causes the fronts to work harder and warp..........so
should i either
1) get my fronts cut and rears adjusted
2) get aftermarket fronts and my rears adjusted....if i do this should i also replace the pads? and what type of rotor should i get?
what u guys think?
no one?
nothing at all?
Old Apr 17, 2009 | 03:04 PM
Coblasts's Avatar
When you replace the rotors and pads make sure the guy uses a torque wrench to tighten the lugs.
Uneven and over torqued lugs are a major cause of warped rotors.
Old Apr 17, 2009 | 03:06 PM
hinow41's Avatar
If you have the money get the after market. and do the front brakes your self.
Old Apr 17, 2009 | 03:07 PM
Jackalope's Avatar
See if they can be turned and sve yourself some money!
