Wheel clicking
sounds like a possible cv axle issue although typically that would be heard while turning. make sure theres nothing caught in the brakes around the rotor and caliper area. Also make sure your little center cap isnt loose ive seen those cause noise issues at the shop
the ss does have a limited slip differential that will making a clickin sound when u back up and then start to move forward in the car. if that is what ur hearing, its normal, but only if it happens when changing direction from backwards to forward.
Ok thanks
Btw do you guys have any recommendations for new head lights the stock ones are terrible. So hard to see at night
GMSC Lighting makes some really nice Retrofits. You'll have to sign up on GM Sport Compact . Net though, because I don't know that he sells on any other site.
