Who here does their own car maintenaince/service
and how much does it cost you?
I just paid 262 bucks at my stealership for the 15000 mile service on my car and I feel like I got screwed over.
I could have done all that for you for $250.
Probably! Can you give us a list of what that service includes? I'm guessing its an oil and filter change and a bunch of inspections. Maybe a tire rotation. You're not due for anything else; the supsension grease fittings are sealed, the plugs and wires aren't due, the coolant isn't due... etc. Maybe an air filter?
$262.00 for an oil change and tire rotation is nuts. There couldn't be anything else.
That's why they call them stealerships.
Just do your own maintinence man. Invest in some tools before mods.
Good luck in the future.
Probably! Can you give us a list of what that service includes? I'm guessing its an oil and filter change and a bunch of inspections. Maybe a tire rotation. You're not due for anything else; the supsension grease fittings are sealed, the plugs aren't due, the coolant isn't due... etc. Maybe an air filter?
New Oil Filter
Tire Pressure
Lube Chassis
Rotate Tires
Full Vehicle Inspection
Top Off Fluids
Clean Battery Terminals
Replace Fuel Filter
Brake Cleaning
What kind of tools would I need?
I would of done all that for you....150 bucks!
Honestly though if you have to ask how or what you need to do that list. Maybe its a good idea for them to do it.
Yah I know, I feel like an idiot right now.
Not for that price, I'll learn how to do it myself and only take the car to them for heavy duty maintenance. (like alignments etc.)
Get a hydraulic one with jack stands from Walmart. It'll run you about $20 or less. Don't even bother messing around with the one that came with the car; its a piece of junk.
Tire Pressure = 25 cents at gas sation
Rotate Tires = half hour if you have jack stands. or, 3 dollars per tire at a tire shop
Top Off Fluids. -= Depends on what needs to be "topped off", but probably nothing
Clean Battery Terminals = Free
Replace Fuel Filter = 34 dollars
Brake Cleaning - Free
so basically if you did all the things they did, probably would have been less than 100 to do, and none of it is hard.
and, i got a 5,000 pound lift, and 2 jackstands from walmart for like 70 dollars.
Oil Change = 40 dollars
I'll go get some good jacks soon and learn how to do this **** myself.
Just hook up with a buddy, relative, or another car guy and get them to help/show you how to do it. Everyone has to start somewhere.
Next time use that money to buy a manual and tools, you'll be way ahead to learn to do these things yourself. And it can be fun, too.
People that don't work on cars get absolutely raped these days.
Everyone's got stories like this but last year my old ford pos sprung a water leak while I was at work. Stopped at the local garage, they said "Oh that's a bad one and that metal pipe is $95 and it takes 4 hours to change so it will be about $400". I said no thanks and nursed it home. Got girlfriend to take me to buy ramps, crawled underneath to look at it, fixed it with a short piece of rubber hose and 2 clamps, about $3. But I really got pissed when I saw that to replace the whole pipe was two bolts and two clamps, about a 10 minute job! Those lyin' rip-off SOBs! And every time I drove past that garage they had cars lined up to be worked on.
Please, guys, I'm not flaming the whole industry, just using this one shop as an example of how bad some places can be. This was an independent shop and dealers usually can't get away with things like that.
I understand that some people are so busy and make so much money it isn't worth it to them to do their own work. But most of us aren't in that position and need to save whatever money we can. And, I know when I do something myself it is done right.
The things on that list are simple and wouldn't take long at all to do. You will definately get a feeling of satisfaction from doing those things yourself.
just my 2 cents, your reality may differ
Fallen, I take it you've never done any work on cars?
I highly recommend getting an experienced helper when you're first learning. You have to develp a feel for how much to tighten bolts and things like that and it's good to have someone watching/checking your work after you. He's especially important when something goes wrong or you can't exactly figure out what it says in the manual.
You don't have to spend a lot on tools, either. Don't buy the walmart $15 sets, but don't spend the huge bucks on Snap-On either. A lot of guys just use Stanley and some of the sets at the car parts stores don't look bad.
again, just my 2 cents
By far the most complicated item on the service list mentioned earlier was the fuel filter change. I haven't looked at the one on the Cobalt yet, but most newer GMs use a special quick-disconnect connector. You have to depressurize the system first but I just do that by pulling the fuel pump fuse and starting the engine a few times until all the gas is out of the lines.
The rest of that list was very basic. I wonder which suspension components they lubed - I don't think we have any grease fittings. Maybe they just lubed the door hinges and the pull cable for the hood.
EDIT - I agree with 05redline - I wouldn't have bothered with the fuel filter either.
thats seems really really early for fuel filter
i just use a normal 32 mm socket *(no supercharger in my way)*
and that fuel filter is the same as they been using for meny years, and is a pain in the A$$
Or just get the one made by Lisle Tools. I paid something like $9 for mine. Yes its aluminum but its perfect for what I need it for; the filter cap is not a high-torque fastener by any means. Of course many people on here just use a regular 32mm socket (or 1-1/4") but I found they are a little too tall and scrape the intake manifold runners.
Actually 15000 miles is a good time to replace them every 15000 or so it really helps keep the fuel pump doing the least amount of work as it can. They are fairly cheap and I replace mine at work every 15k miles. Well im taking my car in wednesday for stage 2, I told them to repalce the oil and the supercharger oil too. Im feeling lazy as of late.
15K is the official replacement interval for the fuel filter? I can't find that anywhere in the Cobalt owners manual. It doesn't show up on either the simplified "Maintenance I" or "Maintenance II" schedules listed there, and neither is it on the next page under "additional required services". Several pages later, they have a table with part numbers for "Normal Maintenance Replacement Parts" but that doesn't even have the fuel filter listed. I remember them being recommended for change every 30,000 back in the 80s but as GM (and everyone else) have stretched out the required services I wouldn't be surprised if they don't consider it due for replacement until 100,000 miles.
Obviously you'll do no harm changing it early, but tacking it onto the "Maintenance I" work (which is what the original poster had his car in for) is unnecessary and just a money maker for the shop.
