Wideband and Windshield Washer
I just finished my supercharger build and have a few minor issues. First is I have an interceptor with the wideband kit and for some reason the wideband quit working a couple days ago. I've checked all the wires and connections and everything is fine but nothing I do makes it work. Anyone have any ideas or even a phone number for Aeroforce? I've sent them emails but haven't got a response. My other problem is after I relocated my windshield washer tank and pump, the pump no longer pumps fluid. It turns on but nothing comes out of the sprayers. I pulled the pump out of the tank and poured fluid straight into the pump and all it does it pull some fluid in and slosh it around but as soon as you release the button the fluid comes right back out. Ideas?
Nope just pull up that plastic cover at the base of the windshield (there's a push pin on each end and then the rest is just held down by those metal clips that all the interior panels are held on with so just a decent pull and it pops free. Then just pull the rubber connectors off the spray nozzles and put the hose back in the opposite direction. Looking at the car from the front, you will put the end with the 90 degree connector on the right spray nozzle and put the Tee connector on the left nozzle and the hose reaches the new pump location no problem
n20saturn
Sep 30, 2015 12:26 AM
