Windows Too Slow!!!
Old Jul 8, 2007 | 12:24 PM
06CobaltSSS's Avatar
Windows Too Slow!!!
Hey guys, does anyone have problems with the windows going up too slow? My driver side seems to be ok but when i role both up at the same time, the passenger just barely crawls towards the top. When ever the driver side is up and i let off the button the passenger one speeds up.
Do you think the car battery is too weak or is going bad? Its not a huge problem but it bugs me cos it shouldn move that slow. Ive cleaned it checked for anything in the way but its nothing. Any suggestions? My guess is that the battery is weak and cant run everything plus the windows efficiently. No sound system or extra electronics either!
Old Jul 8, 2007 | 12:26 PM
3ds138's Avatar
mine does the same.. I thought it may have had to do with my tint restricitng it a bit.. weird..
Old Jul 8, 2007 | 12:32 PM
yea i always thought that too but it seems like its getting worse so i dunno. I think im going to get another battery
Old Jul 8, 2007 | 12:39 PM
cougar2588's Avatar
mine does it too. its not the tint, cuz mine did it before i had my windows tinted and does it now that they are tinted. it might be the battery. at night, when ur lights are on, hit both the window buttons up or down, and u can see the healights kinda dim for a second, and then go back to normal... prolly just the battery, nothing to worry about though, and i dont think its worth going to buy a whole new battery.
Old Jul 8, 2007 | 12:46 PM
Cirrus's Avatar
Mine does it too.. Even worse = driver, passenger, and sunroof all at once. Add AC and blasting music = hahha.
Old Jul 8, 2007 | 12:47 PM
BooSSted's Avatar
My old Neon used to do the same thing. I don't think there is really much we can do about it. It's just one of those American economy car things, haha.
Old Jul 8, 2007 | 12:57 PM
InfinityzeN's Avatar
Mine doesn't do it at all. Both windows open and close at exactly the same speed. Also my lights don't dim when I hit the windows.
I'm going to go with battery, alternator, or wiring problems. Go to Autozone or some other parts store and have them test your battery. They'll do it for free. If it is the battery, an Optima Yellow Top will totally take care of the problem for about 5 years.
If it is not the battery, you can check the output on your alternator. A shop can do it or if you know someone with a voltmeter, they can do it. Check it right at the alternator. You should be pushing 14.4v. If you are, check it at the battery with the car running. Still 14.4v, turn on the lights and radio and check again. The voltage should have dropped no more than 5% and be the same at the alt and battery. If at the alternator you get 14.4 and the battery you get less, the wiring problem is between the alt and the battery. If at the alt you get less then 14.4v with the car running and nothing on, the alt is going bad.
Finally, if the battery is good, the alt is good, and the wiring from alt to battery is good, you got a problem in your electrical somewhere. Most likely it will be weak grounding or surging.
A battery/electrical system stabilizer can help. So will an improved grounding system. I would also go through and find all the little grounds you can. disconnect them (with the battery disconnected first!), make sure they are clean and their connecting to bare metal, and reconnect them down tight. Also make sure there is no corrosion on the wires and none of the wires are wearing. Clean or replace as needed with high quality copper wire.
Old Jul 8, 2007 | 01:36 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Mine does it as well... always has. They will go down at the same speed... butt going back up... the passenger side is usually 3-5 seconds slower.
Old Jul 8, 2007 | 01:49 PM
Everyone post model years. I got an '07 with no problems. It might be something that just effects 05 and 06's.
Old Jul 8, 2007 | 02:34 PM
Of course... the 05
Old Jul 8, 2007 | 02:36 PM
an0malous's Avatar
yes.
and everyone in this thread officially has OCD.
Old Jul 8, 2007 | 02:44 PM
LSCobaltlover05's Avatar
Ya mine does it, i have an 05. When i try to put my drivers up just by itself it takes forever. I think its just a Cobalt thing.
Old Jul 8, 2007 | 02:49 PM
JPizzle's Avatar
Mine are ok, but i loose the chrage on my battery occassionally & that's when the windows don't even wanna roll up. I have window automation w/ my Viper alarm & the windows go up & down 2X quicker
Old Jul 8, 2007 | 02:56 PM
FlintIonQC's Avatar
My 07 Ion QC doesn't do it, they are even and fast.
Old Jul 8, 2007 | 02:58 PM
humanpiston's Avatar
i have an 06 and it does the same... but i have noticed that in other cars as well.. not just ours... i dont think its really a big deal...
Old Jul 8, 2007 | 04:13 PM
stxSS07's Avatar
my 06 does it too...i've been wonderin if anyone else had that problem since i brought it home
Originally Posted by an0malous
yes.
haha....very true
Old Jul 8, 2007 | 04:16 PM
JCswoosher2's Avatar
My passenger side is slow as crap.
I hate that feelign where your sitting there with the your window rolled up waiting on the other. and its hot as hell. It pisses me off. Im not patient
Last edited by JCswoosher2; Jul 8, 2007 at 04:16 PM. Reason: Automerged Doublepost
Old Jul 8, 2007 | 04:28 PM
Blankobalt06's Avatar
YEEHAWW!!! Mine too. 06 with passenger 3-5 seconds behind driver side. I wish cars had downloadable updates like a software program. That would rock.
Old Jul 8, 2007 | 05:25 PM
RaineMan's Avatar
+1
If I hit the button... and the window moves at a reasonable speed... I'm fine with it.
Better than having to do it by hand.
Old Jul 8, 2007 | 06:24 PM
smartmts123's Avatar
05... and my passenger window really doesn't want to close. ever.
Old Jul 8, 2007 | 08:23 PM
I just timed mine...varies...1.5 to 2 second delay.
Old Jul 8, 2007 | 08:41 PM
yellowcar2006's Avatar
lol... same happens to me...
Old Jul 8, 2007 | 08:44 PM
madmark's Avatar
its the seals, put dry lube on the seals and clean the windows often
Old Jul 8, 2007 | 08:49 PM
nonSS's Avatar
Originally Posted by RaineMan
+1
hey i don't have this prob because i have to do it manualy so ha ha ha ha but my friend poppagun (mike) on here does this and we just laugh at him
Old Jul 8, 2007 | 08:56 PM
pjk91's Avatar
i have an 07. yeah the pass side is slower. add the sunroof at same time and its a tad bit slower but not something to bring it in over. ill bring it in when it doesnt work period.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dieGone
Sep 23, 2015 10:20 AM
TylerJHowell
Sep 21, 2015 06:47 PM
