WTF is wrong with my temps
Old May 24, 2010 | 08:56 PM
roderick's Avatar
Ok so my cars temps use to be right around 135-140 after or during a wot pull from 40-120 now my car has been sitting for about 8 months and my temps are at 175-180 from a 40-120 pull. I checked my ic pump working just fine. Could it be the gas from sitting so long?
I have a h/e
tvs stock pulley
80#injectors
Old May 24, 2010 | 08:57 PM
nhanson's Avatar
talking about coolant or IAC?
coolant should be 180+
Old May 24, 2010 | 09:07 PM
roderick's Avatar
my iat 2 the heat my sc makes
Old May 24, 2010 | 09:08 PM
Nighthawk243's Avatar
A slightly clogged H/E perhaps?
Old May 24, 2010 | 09:17 PM
lsjwannabe's Avatar
Possibly air in the system would be my first guess.
Old May 24, 2010 | 09:18 PM
EdCobaltSS's Avatar
how long was the car running before the pull?
Old May 25, 2010 | 12:28 AM
roderick's Avatar
car ran for about a hour or 2 when I was tuning. Also for the air in the system could be I drained my h.e and added more coolant I have yet to test see if that was it.
here is my log files one from just driving in town. ones from cruising at 60 and ones my wot pull. I still need to tune some on the wot pull I know but if you look at the temps it starts out at 140 and slowly goes up to 174 iat2 going 90 with iat at 84.http://www.youshare.com/Guest/a75767/DisplaySimple
Old May 25, 2010 | 01:20 AM
Sumasianluv's Avatar
When your doing a coolant flush, you have to keep ur car running, preferably to engine temp,while filling up the coolant to the proper fill level, having it running while filling it up prevents aeration in the system.
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
