Zzp install-now eng per reduced on?
Old Apr 15, 2017 | 02:12 PM
Jbishop0352's Avatar
Okay guys this car is killing me. Got everything in and cranked getting the check eng light and can barely drive with eng power reduced staying on. Want to go to adance to clear and run codes but this think barely drives at all and is cutting off on me . Is there a way to clear thus or is this typical when replacing the pcm? I got the one that was tuned from zzp.
Old Apr 15, 2017 | 08:36 PM
zeeky420's Avatar
Did you send zzp the one off your car or did you get another one off a junk car?
Old Apr 15, 2017 | 09:14 PM
If you disconnect the battery, the codes will clear but its likely to come back. Get a reader and check them at home.
Old Apr 15, 2017 | 09:40 PM
mrbelvedere's Avatar
email zzp about the problem they will probably want the pcm back to reflash it
Old Apr 16, 2017 | 09:40 PM
tomj77's Avatar
well what is the code its throwing? u wanna fix the problem, that's where u start
Old Apr 16, 2017 | 09:49 PM
Hey so I got the pcm from zzp and it's been a nightmare. I'm sure they will want me to send back or I hope so. I ordered a newer obd scan tool and have one I'm grabbing from my brother.
The major issue is the pcm with crank sensir that usually firea for the Cas relearn . I'm working with zzp now but the communication is very short and a day in between responces. Hopefully they will take this one back and send the one with the right stuff needed so I can get back on the road.
