3" Custom Stainless Steel Exhaust
$ 4 SALE $ Any one intrested in buying a 3inch exhaust custom from manifold back $525 with shiping DEREKBIGGS2002@yahoo.com
with the 3 inch exhaust i gained 29.5 and another 12 with my ported and polished exhasut manifold, and you can really noticed the lower end torque18-25lbs plus im going back for a custom intake cause the one i bought from ingen is a pic of junk and the way it was made it rubbed a whole right in it casue of the way it sits in the engine bay he does a lot of custom applacations for cars, and we know a way to stop it from throwing of the check engine light off too
Originally Posted by JMAc88
This is the exhaust i am running. I really like it, sounds great. The only problem is i keep throwing the p0420 code.
JMAc88 where the sensor plugs into the exhaust take the sensor out and go buy sum washers that will fit around the o2 that equal about 3/16th of an inch and then bolt your sensor back up to your exhaust and by backing the sensor out a little bit should solve your problem with that P0420 code that your getting in the mean time before you start to do that disconnect your neg and positive from your barttary and buy the time that you have completed the process with the o2 sensor plug the battary back on that will allow your ecu/pcm to reset and you shouldnt have a problem anymore with the light coming on the code is saying that you have a bad cat which we both no is not tru casue you just bought it the sensor is sensorring to much flow and thinking the cat is bad but by doing this should solve the ploblem let me know how it wrks 4 you
Originally Posted by SSpartan
wow nice gains!
i live in Michigan so if this guy in wisconsin is for real i would like to see this intake you guys fab up and give me his contact info!
when we get it fab and made i willo take some pics and i will post them for you too see it might be a few weeks k plus it can be any color you wanted as well im proablly going to go black but i will show post and some pics of before and after its painted and if you like i will give you contact info sound good
