clar bar
clar bar
Ok so i got a clay bar and sorta did part of my car with it but i really need some tips for next time. I half fucked up and half didn't so I'm not sure what to think so far.
Am i supposed to use the clay bar with the car dry or wet?
Isn't there some chemical I'm supposed to spray on the area prior to the bar?
And when do u usually turn it?
im sure these might be answered somewhere and im an ass for not reading but i wasnt sure
The car should be dry and clean. The kit should have also came with a spray that you spray on the area to be clayed to use as a lubricant. You then move the clay over the sprayed area until its smooth. Do one area at a time, then once done, turn the bar. Hope that helps
Usually most clay bars com with some of car detailer that you spray before you run the clay bar over and it helps lubricate the clay. As for turning it, I guess it all depends on how bad the dirt/overspray/sap, whatever was on your car was. Usually the clay bar is darker (dirtier) and you just flip it over or knead it until you get a clean side.
This whole thing can be scary (I bought a kit and was too afraid to use it for 6 months) but it's not that bad once you get it figured out.
The car should be dry, but recently washed.
Use a quick detailer with the clay bar. Most kits should come with some, but if not Mothers and Meguiars both make good ones. This is needed so the clay doesn't just stick to the car.
Turn the clay every few minutes, or as it gets dirty. Keep looking at the clay, and once it looks dirty either just use a different part or kneed it up to get fresh clay.
good info...i jus bought a claybar after i saw pics of the results of another black cobalts owner did his an i had to have that showroom shine...i'm doing mine in a day or two b4 the big cobalt meet at cabelas here in east pa
lol ok cool... i bought the mothers kit but didnt know wft was up... i just used it a bit with the car wet from being "rinsed" right after washing it but i had a feeling i was messin it up
DANRICKARD
Oct 1, 2015 12:08 AM
