Engine Bay Clean
What do you guys figure is the best way to clean the dirty/dust out of the engine bay. THe no way of doing it with a cloth/bucket of water, but I just dont want to take a hose and go wild. What do you guys sudgest?
??? how do you guys do it??? |
i drove into my pool and did a burnout
i use armor all wipes and my engine bay is spotless
haha well i guess if I had a pool i would consider that! Would it be possible to have the hsoe on low low pressure and run it on the sides of the engine bay?
go to a car wash and spray it down with the "engine cleaner" that they should have as an option.
If engine bays weren't meant to get wet they'd be sealed from the bottom :lol:
A little soap and water isn't going to kill anything... If you're that worried cover your air filter & fuse box/ECM before you start. |
i spray my shit with the hose, never had a problem.
Also, be careful when using the engine cleaner hose, it took all the black stuff off the random sticky panel on the passenger side shock tower. What does that black thing even do? I'm talking about the triangular aluminum? piece on the shock tower just behind my lovely 15mm wrench. https://www.cobaltss.net/gallery/fil...0016416974.jpg |
just dont try and spray water up in the box and filter and you will be fine. reign is right
Originally Posted by REIGN SS
(Post 3755383)
How fast do you think that water is hitting stuff at 80mph on the freeway in the rain? Just don't hold the nozzle 2 inches away from everything. |
Okay that was the answer that I was looking for. BTW our car wash's suck ass haha so will the regular pressure at a normal car wash work or should I do it at home with the garden hose. Also using soap.... just the soap option at a car wash or is there some different/special/better shit?
Originally Posted by ls1fbody
(Post 3755405)
Originally Posted by krazycobalt
(Post 3755459)
(Post 3755459)
As a rule of thumb (for me), I always just keep from spraying any sort of pressure directly on the fuse box or ECU. Garden hose, I don't mind hitting it. As for the soap...I've always preferred just using soapy water, getting it wet, wiping it down, and rinsing. |
Originally Posted by HunterKiller89
(Post 3755461)
its a heat shield.
(Post 3755459)
In all honesty, I tire shine the HELL out of mine.
Not only does it work, it lasts a while, and then when it gets dirty again it's really easy to whipe off with a microfiber or even a california duster. |
I just spray mine down with simple green. Rinse, simple green, wait a while, and rinse again.
what do u guys suggest i do being i have the hahn kit and the intake is right in the engine bay?
i would say cover it with a plastic bag and tie it closed, and probably wrap several times, better safe then sorry.
k. a couple garbage bags zip ties and or duct tape would work nicely. lol
yea that's what i would do.
also its good practice not to spray directly into the alternator.
you don't want good picture of mine, haha, looks like the day i bought it.
before Simple Green:
https://www.cobaltss.net/gallery/fil...9/DSC01732.JPG After Simple Green: https://www.cobaltss.net/gallery/fil...9/DSC01734.JPG i know it's a little dark but you can clearly see all the dirt is gone. |
