Show & Shine Detailing, washing, waxing, paint care, wax, etc.
Engine Bay Clean
Old Apr 19, 2009 | 09:09 PM
krazycobalt's Avatar
Engine Bay Clean
What do you guys figure is the best way to clean the dirty/dust out of the engine bay. THe no way of doing it with a cloth/bucket of water, but I just dont want to take a hose and go wild. What do you guys sudgest?
??? how do you guys do it???
Last edited by krazycobalt; Apr 19, 2009 at 09:09 PM. Reason: Automerged Doublepost
Old Apr 19, 2009 | 09:14 PM
Plz4Camaro's Avatar
i drove into my pool and did a burnout
Old Apr 19, 2009 | 09:17 PM
Jared B's Avatar
i use armor all wipes and my engine bay is spotless
Old Apr 19, 2009 | 11:58 PM
haha well i guess if I had a pool i would consider that! Would it be possible to have the hsoe on low low pressure and run it on the sides of the engine bay?
Old Apr 20, 2009 | 01:01 AM
wardzach2007's Avatar
go to a car wash and spray it down with the "engine cleaner" that they should have as an option.
Old Apr 20, 2009 | 01:03 AM
hatrickstu's Avatar
super clean, wash, soap, water, win:
Old Apr 20, 2009 | 01:06 AM
REIGN SS's Avatar
Original Hayden Fanatic
If engine bays weren't meant to get wet they'd be sealed from the bottom
A little soap and water isn't going to kill anything... If you're that worried cover your air filter & fuse box/ECM before you start.
Old Apr 20, 2009 | 01:10 AM
ls1fbody's Avatar
Haz l33t wheelz.
i spray my **** with the hose, never had a problem.
Also, be careful when using the engine cleaner hose, it took all the black stuff off the random sticky panel on the passenger side shock tower. What does that black thing even do?
I'm talking about the triangular aluminum? piece on the shock tower just behind my lovely 15mm wrench.
hatrickstu's Avatar
just dont try and spray water up in the box and filter and you will be fine. reign is right
Old Apr 20, 2009 | 01:12 AM
ls1fbody's Avatar
Haz l33t wheelz.
i always tell people that when they're worried about water in the engine bay. then they use the pressure excuse.
How fast do you think that water is hitting stuff at 80mph on the freeway in the rain?
Just don't hold the nozzle 2 inches away from everything.
Old Apr 20, 2009 | 01:22 AM
Okay that was the answer that I was looking for. BTW our car wash's suck ass haha so will the regular pressure at a normal car wash work or should I do it at home with the garden hose. Also using soap.... just the soap option at a car wash or is there some different/special/better ****?
HunterKiller89's Avatar
its a heat shield.
Old Apr 20, 2009 | 01:26 AM
REIGN SS's Avatar
Purple Power!
Old Apr 20, 2009 | 01:28 AM
WhiteFiver's Avatar
Yeah, regular pressure at a wand wash is fine. Just don't hold it 2" away from ****, as was already stated.
As a rule of thumb (for me), I always just keep from spraying any sort of pressure directly on the fuse box or ECU. Garden hose, I don't mind hitting it.
As for the soap...I've always preferred just using soapy water, getting it wet, wiping it down, and rinsing.
Old Apr 20, 2009 | 01:30 AM
ls1fbody's Avatar
Haz l33t wheelz.
Originally Posted by HunterKiller89
its a heat shield.
for what? lol, there's nothing there to cause heat.
there's usually an engine/tire setting. use it, it works great, but only on the engine, nothing else.
Old Apr 20, 2009 | 03:08 AM
SSSCEnthusiast's Avatar
In all honesty, I tire shine the HELL out of mine.
Not only does it work, it lasts a while, and then when it gets dirty again it's really easy to whipe off with a microfiber or even a california duster.
Old Apr 20, 2009 | 03:20 AM
dragonslayer27's Avatar
I just spray mine down with simple green. Rinse, simple green, wait a while, and rinse again.
Old Apr 20, 2009 | 03:26 AM
Killa SS's Avatar
what do u guys suggest i do being i have the hahn kit and the intake is right in the engine bay?
Old Apr 20, 2009 | 03:32 AM
i would say cover it with a plastic bag and tie it closed, and probably wrap several times, better safe then sorry.
Old Apr 20, 2009 | 03:33 AM
Killa SS's Avatar
k. a couple garbage bags zip ties and or duct tape would work nicely. lol
Old Apr 20, 2009 | 03:36 AM
yea that's what i would do.
Old Apr 20, 2009 | 03:45 AM
RBC's Avatar
RBC
also its good practice not to spray directly into the alternator.
Old Apr 20, 2009 | 09:28 AM
Jared B's Avatar
Old Apr 20, 2009 | 11:06 AM
ls1fbody's Avatar
Haz l33t wheelz.
you don't want good picture of mine, haha, looks like the day i bought it.
Old Apr 20, 2009 | 11:54 AM
before Simple Green:
After Simple Green:
i know it's a little dark but you can clearly see all the dirt is gone.
